Old 08-03-2019, 02:44 PM   #21
TheHubbardBus's Avatar
Coachwork: IC / Amtran
Chassis: CE300
Engine: International T444e
Rated Cap: 23
Originally Posted by HazMatt View Post
Dahmer Disclaimer: No scatological meanings were intended. Those seeing such have a potty mind.
I don't know what Ella Fitzgerald has to do with any of this. But your post was still funny.
Originally Posted by roach711 View Post
A little C4 would blast that steel off in a flash and we can buy it at the grocery store now!
I prefer ANFO when I'm bulking. I'd save the high-brisance explosives for the cutting cycle.
Oh yeah...
The spot weld cutter worked great, but probably not nearly as fast as RexPearl's method (great thread and great info, BTW, Rex. Much appreciated). It took me 10-15 minutes per window. That includes the time needed to center-punch each weld, drill the welds out, and remove the panel sections. It does not include the time spent removing the windows themselves or the screws securing the panels to the ribs. Each window had 25-30 welds per.
Go away. 'Baitin.
Our Build: Mr. Beefy
Old 08-24-2019, 11:45 PM   #22
Year: 95
Engine: DT408
You can try a spot weld cutter, or a spot weld drill bit. I tried both and settled for the bit. I drilled mostly thru the first layer then gently popped the weld with a chisel between the panels, cleaned it up with the grinder and that worked well.
Klink63 is offline   Reply With Quote
