Old 07-30-2019, 05:11 PM   #1
Coachwork: AmTranRE
Rated Cap: 69
Interior Panel Removal: New Method?
Hi all,
Not sure if this has been discussed but it worked great for me to get those spot welds and panels out in a hurry.
Using a cut-off wheel, simply cut the weld out! Then grab the metal with pliers and give it a tug. Came out quick clean and easy.
File Type: jpg 2C531998-92D1-480F-8B0A-CBF8E52D9457.jpg (277.4 KB, 26 views)
File Type: jpg 7075D491-A89C-4A93-BFD9-D132CC1FEB1C.jpg (214.0 KB, 18 views)
RexPearl is offline   Reply With Quote
Old 07-30-2019, 05:12 PM   #2
Coachwork: AmTranRE
Rated Cap: 69
Well... not sure why theyíre upside down?!
Old 07-30-2019, 07:15 PM   #3
I'm not sure what I'm looking at in these pics. If you want to avoid getting your images rotated on you, convert them to PNG before uploading them to skoolie.net.
Old 07-30-2019, 08:22 PM   #4
HazMatt's Avatar
Chassis: IH 3800, 8 window
Or do a head-stand while shooting the shot.
Old 07-30-2019, 08:27 PM   #5
Johnny Mullet's Avatar
Engine: T444E 7.3L
At least you got the job done! Kudos to you!
Old 07-30-2019, 09:16 PM   #6
Coachwork: AmTranRE
Rated Cap: 69
This is the top of the interior paneling; sits under the windows in my bus. I donít know about anyone elseís, but mine had about 30 screws per panel, a single rivet and about 20 spot welds which made removing them a very big deal.
I tried a few methods: Cutting the entire spot welded seams out- this took time, made a lot of sparks and ate through cutoff wheels.
Then I tried just making one cut through each spot weld. This wasnít too bad but I still thought it could be done better.
Next I tried just grinding the weld off the interior panel and not cutting the part it was welded to. This actually worked well and did not leave jagged metal for a laceration hazard BUT it took more time.
Finally, I thought I should just cut the welds out and see what it thought. It made the job much more manageable. Iím going to reskin the windows and will insulate and add paneling inside anyway so the hazard of sharp metal will only last a little while.
Hope the word pictures help clear it up?!
Thank you! FINALLY got through your build page just today. What a fantastic ride. I may have to ding dong you for some T444e questions sometime... for now Iím still in demo inside and paint outside.
Old 08-02-2019, 09:31 AM   #7
TheHubbardBus's Avatar
Coachwork: IC
Engine: Navistar T444e
Rated Cap: 24
Is it possible to drill through the center of each weld, without significantly compromising the metal (window channel) it's attached to, so you could remove the panels in their entirety?
- Sharon & Jody
Old 08-02-2019, 09:46 AM   #8
Sleddgracer's Avatar
Chassis: still looking for my bus
the welds are much harder than the surrounding material - might be a frustrating process to drill them out - you never know though, it might be worth a try
Old 08-02-2019, 10:43 AM   #9
Coachwork: IC
Rated Cap: 24
I found this spot weld cutter kit on Amazon. Many other variants for less but this one seems highly rated. Thinking we might pick it up & give it a shot.
https://www.amazon.com/Blair-11096-C...=fsclp_pl_dp_1
- Sharon & Jody
Old 08-02-2019, 10:51 AM   #10
I like that - I was thinking maybe a small hole saw - that cutter might work even better
Old 08-02-2019, 10:56 AM   #11
HazMatt's Avatar
THAT is something that I have wanted to do, but haven't yet found a way.
Old 08-02-2019, 11:19 AM   #12
Coachwork: IC
Rated Cap: 24
Well, I'm pressing the 'buy' button here in the next 5 mins. Should have it today, and will be testing it out this weekend. I'll let y'all know how it works!
Oh, and HazMatt...
- Sharon & Jody
Old 08-02-2019, 11:44 AM   #13
The spot weld drill didn't seem to want to go through the hard metal. It was worth the $37 for the electric shears to make clean, quick work of the panels. It takes about 10 seconds to cut the metal clean just below the lip. Drilling the spot welds, of which there are 100's of them, is too much time consuming labor to end with the same result. The shears come in handy on any other sheet metal you're cutting on the bus.
https://www.ebay.com/itm/Kett-K-200-...ty!30534!US!-1
Old 08-02-2019, 12:00 PM   #14
Coachwork: IC
Rated Cap: 24
Then again, it's only a waste of time if it's time I'm not enjoying. And making holes in things is actually something I truly enjoy.
- Sharon & Jody
Old 08-02-2019, 01:25 PM   #15
HazMatt's Avatar
As a bachelor, there is a considerable interpretive difference in defining the pleasure attained from "making" a hole, compared to the context for someone in a committed relationship...
Old 08-02-2019, 01:59 PM   #16
I used a similar method involving a chisel bit on my air hammer.
Roll Your Own Build Thread
Old 08-03-2019, 11:06 AM   #17
Coachwork: IC
Rated Cap: 24
I'm thinking if you have to make a hole, you may be doing it wrong.
Disclaimer: The views expressed in this post are solely those of THB, and are in no way endorsed or supported by Jeffrey Dahmer, Dahmer Industries, or related affiliates.
- Sharon & Jody
Old 08-03-2019, 11:17 AM   #18
HazMatt's Avatar
ROFL
SEE! Exactly my point! Taken contextually, to me that means "making" whoopie with some strange.
Dahmer Industries makes due, do...
Dahmer Disclaimer: No scatological meanings were intended. Those seeing such have a potty mind.
Old 08-03-2019, 01:32 PM   #19
roach711's Avatar
Rated Cap: 19
A little C4 would blast that steel off in a flash and we can buy it at the grocery store now!
The Roach Motel
Old 08-03-2019, 02:04 PM   #20
HazMatt's Avatar
Is that offered in the 100mL size?
The TSA can be such pests...
