Old 12-28-2015, 11:36 AM   #1
Engine: Navistar T444E Disel V8
Rated Cap: 71
Interior Water Tanks, etc
I'm putting my fresh water tank inside under my couch/side table and my gray water outside underneath the bus, mostly because I can't think of a way for water to drain into it other than gravity.
My question is how do I monitor my fresh water tank to avoid overflowing it, because it's my understanding that there's a vent on top that water can come through. Does anyone have any suggestions ideas on how to deal with this overflow up top? Can't be too good for an interior tank.
Intalleyvision is offline   Reply With Quote
Old 12-28-2015, 11:49 AM   #2
austin1989us's Avatar
Chassis: TC/2000
Engine: Cummins 5.9TA
Get one of these and attach your vent line to it. When water squirts out of the vent hole it's full.
http://www.amazon.com/Valterra-A01-2.../dp/B00C5TEJJC
Another option is to put one of these little water trough float valves in your tank and plumb the tank into your city water line.
http://www.amazon.com/Little-Giant-T.../dp/B000HHS9RM
austin1989us is offline   Reply With Quote
Old 12-28-2015, 11:54 AM   #3
Chassis: TC/2000
This one has a vent hole in it too, but no city water connection like the last one did.
http://www.amazon.com/JR-Products-32...QGM1BDEG0JRK60
Old 12-28-2015, 12:35 PM   #4
Chassis: Blue Bird
Engine: ISC 8.3
We don't know how to monitor and avoid overflow; it seems more common to design so that overflow isn't problematic. (water may slosh out the vent while driving, too.)
Use a fresh water tank that has a threaded vent hole so you can attach tube to extend the vent to a place where spills are OK. The little patch of screen in that Valterra panel probably has a 1/2" tube barb on the back side for this purpose. If you don't like the Valterra part and want to fill another way, the vent could instead drop out through the floor of the bus (you'd still want some kind of screen to keep insects and debris out).
Old 01-10-2016, 10:28 PM   #5
rossfree's Avatar
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
Your water tank does not have to be mounted above your grey water tank. Your sink and shower do. You use a pump to pull water out of your water tank for use at the sink and shower and gravity takes it from there to your grey water tank.
rossfree is offline   Reply With Quote
Old 01-11-2016, 10:07 AM   #6
Rated Cap: 71
Right right, was just curious about the grey tank. I'm mounting it below the bus and the fresh water inside the bus
