Old 02-19-2005, 03:44 PM   #1
pangaia's Avatar
Leaks here and there
Howdy all
Well, I found another leak that appears only when the bus is tilted to the right side. Right above the sliding window on the driver's side above the switch paneling. Water leaks right onto the panel box, pooling around the defrost vent propably to drip on the floor.
I believe it has something to do with the poor draining channels along the side of the roof itself. How have folks here been dealing with those leaks. Naturally here in Calif, we get little rain but the past few weeks have proven to be really wet and crazy. However once the bus is ready for the road other states will be less dry.
Tips, anyone? Thanks!
'Before you go out seeking revenge you must first dig two holes'--Chinese Proverb
Bright Blessings of the Mother upon you ;)
1990 International Ward Volunteer "Fantastic Voyage"
pangaia is offline   Reply With Quote
Old 03-27-2005, 09:07 AM   #2
I check for leaks with sprinklers and/or a garden hose running full blast to FLOOD the area I'm checking.
I don't recommend using silicone sealant, as the acetic acid used to cure the rubber can corrode the metal surrounding/contacting it.
I use butyl rubber sealants only. Tough and resiliant, and available.
Some may be paintable as well.
Ryan Grimm is offline   Reply With Quote
Leaks Gearhead94 Conversion General Discussions 13 12-06-2016 01:49 AM
Newbie: ElDorado/Aerotech shell has soft roof/leaks. HELP Doggone Shortie Coach Conversion Projects 1 05-19-2010 11:14 AM
Lots of leaks when it rains Atridox Short-Bus Conversion Projects 2 05-03-2010 01:08 PM
Idea for finding air leaks with air brakes crazycal Conversion Tutorials and How-to's 9 08-21-2008 09:15 PM
Woodstove in my bus leaks smoke. arfisher83 Conversion General Discussions 12 01-28-2008 09:14 PM
