Old 07-19-2018, 04:51 PM   #1
Led headlights
I am replacing my headlights with LED headlights , they are a hi/low beam and when plugged in the low beams are strobing and the hi beams work just fine .
I bought anti flickering wiring harnesses and plug them in and now the low beams do not work and the high beams are just fine . I tried switching the wires around to see if the connection was wires backwards or something and it has yet to work . Below are photos of what I purchased.
I’m wondering if anyone else is having this issue and what was used to make the Low/high work properly ?
Thanks Tim
083AF816-A1C6-40D4-A8FC-53DD30E4D4AE.jpg   E1DF4320-ACEE-4EF1-8E02-75C8ACFA91BC.jpg
Tattooguy88 is offline   Reply With Quote
Old 07-19-2018, 06:45 PM   #2
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Where did you purchase your LED lights? Online? SUPERBRIGHTLEDS.COM would help you if you got your lights from them.
Old 07-19-2018, 06:55 PM   #3
Awesome thank you , I’ll check it out and see if it trouble shoots . I purchased them on eBay. They are the same headlights most people I have seen replace theirs with
Old 07-19-2018, 07:22 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Try this:
LED Headlights
headlights, led lights
