07-20-2017, 04:32 PM
Rated Cap: 83
Leveling Ground / Leveling Bus
(I'm not talking about a completed skoolie)
I'm working with a fairly sloped parking for my conversion, and moving it isn't an option. Any ideas to get some level ground?
https://www.amelia-bartlett.com/the-skoolie/
07-20-2017, 04:38 PM
Something like this: https://www.etrailer.com/Camper-Jack...hoCGjAQAvD_BwE
Or make your own out of lengths of 2x6. That is what I did.
07-20-2017, 04:59 PM
i suppose driving it onto boards on one side, or jacking n blocking up is out of the question...
07-20-2017, 05:06 PM
Rated Cap: 83
I was thinking of using stacks of scrap plywood I have laying around - it's thick, 3/4 I think.
Chev49, I've been toying with the idea... I just don't have too much room to move. I think its ultimately the way to go, whether with my own blocked ramps or purchase some fancy ones
I figured a quick post might entice some interesting ideas too
07-20-2017, 05:50 PM
Have you thought of some heavy duty bottle jacks to lift it and then block it when level? Should be able to rent them if not find some to buy.
07-20-2017, 08:27 PM
Scoot the bus forward 4', dig out about 6" of dirt, form and pour a 4 ft square pad to back up on. Just be sure to get the surface level with the existing driveway and add an "X" of rebar in the center of the pour and you will be good to go. Each pad will use a little less than a cubic yard of concrete if the level of the drive isn't a whole lot higher than the original dirt Jack.
07-20-2017, 11:32 PM
Traveling
Engine: 5.9L Cummins
Rated Cap: '00
Any railroad ties laying around?
07-21-2017, 06:23 AM
Rated Cap: 83
No railroad ties
07-21-2017, 06:32 AM
Good thread...I'm in the same predicament. Waiting for more suggestions....
I do like the link you posted PNW_Steve.
07-21-2017, 07:46 AM
Year: 92
Engine: DTA360 5.9L
ive had the same problem. easy fix but a hard hour of shoveling. dig under the tires lol. thats what i did. then when i needed to get up i just made the hole into more of a ramp and out it went.
i had to make my front even with the back and dug a good 1' by 2' hole for each front tire and it fits right in. this may not help if you dont have your own property though.
07-21-2017, 10:17 AM
Chassis: Blue Bird
Engine: ISC 8.3
If digging a hole isn't an option, maybe the inverse is: make a pile of rocks and gravel. When building such a pile on soil, especially soft soil, start with larger rocks (2+ inches diameter) on the soil and put smaller stuff on top to make it smoother. The site OP pictured looks kind of woodsy; maybe suitable rocks can be found around the yard. Some in the picture looked a bit angular or sharp; it's probably good to minimize use of those to avoid having one get turned pointy end up and puncturing a tire.
07-21-2017, 12:57 PM
Rated Cap: 83
Unfortunately I'm working with 4 of 6 tires on concrete...
07-21-2017, 12:59 PM
Rated Cap: 83
Great idea! Considering this too. Avoiding sharp sandstone here is no easy feat, but I'm sure I can find something.
07-22-2017, 11:45 PM
That would be my first idea too.
Just starting out. Hope I can help others and learn.
My twitter: @DixieBushcraft
Facebook: www.facebook.com/DixieBushcraft/
07-23-2017, 07:57 AM
Ditto here. Why can't it just be jacked up and cribbed?
07-23-2017, 09:23 AM
Rated Cap: 83
My jacks capacity is only 2 ton. Wouldn't I need something heavier duty?
07-23-2017, 10:48 AM
Why not just work on it the way it is for now? Many suggestions have come to you and there aren't many more except for a crane, skyhook or a chopper to lift it.
My front end is 2 feet lower than the rear and it doesn't bother me to work on it. Yours should be a piece of cake.
Conversions do cost some $$ to do.
07-23-2017, 11:02 AM
Rated Cap: 83
I hear ya John, I'm going to contact my local airport for an available heli
LOL
Seriously though, I've been working with it and it's... ok.
Thank you everyone for sharing suggestions!
07-23-2017, 11:50 AM
you can buy a 20 ton bottle jack from harbor freight pretty cheap.. or wait.. you are in knoxville right now right? I could bring you mine to borrow to get your bus cribbed.. when im on my way back to florida. (jack it up then crib under it then jack down)..
07-23-2017, 11:51 AM
as far as level.. I think having it level, at least a whole axle makes sense fro ma body flex point of view.. and for sure if its going to get a roof-raise.
