Old 03-13-2014, 12:31 PM   #1
Engine: 190hp 5.9 Cummins
Low cost, Great looking moderan Tile Couter tops.
As a contractor, I have installed close to 200 counter tops over the last 5 years. I don't use cement board, or mortar beds anymore, as they are a out dated, less effective systems.
These are the systems I use. After completing a install yourself, you will love this system.
This first video still uses ply wood as a sub strait. Schluter®-DITRA uncoupling membrane is installed on top of the plywood to protect the tile covering from expansion and contraction, and water proofs the surface to protect the plywood below from water infiltration.
This system eliminates the wood all together, eliminating the chance of water infiltration causing mold.
The Schluter KERDI-BOARD is available in thickness from 1/2" to 2". The 2" is what is used as counter top substrait.
This system is more suitable for bus installations due to the weight savings, and vibration resistance.
IMO best tiles to use are a high gloss, polished porcelain tile, as it is the hardest of the man made, sealed products.
My favorite size are the 24 x24, and the 12 x24. This looks amazing with few grout lines.
I could do a video, but I feel it's pointless due to how well the manufactures video's are made.
Old 04-08-2014, 07:21 PM   #2
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Re: Low cost, Great looking moderan Tile Couter tops.
Is this something only available up north? I checked Lowes & Home Depot & couldn't locate it. I'm in California
Old 04-08-2014, 11:07 PM   #3
You may have to ask for it.
Only the biggest stores here carry it. The rest it's special order, but still the same cost.
Old 04-17-2014, 10:29 PM   #4
Thanks for the videos, I'm curious as to how light the Kerdi-board is, what kind of weight savings are you looking at compared to what most people would use?
PowerDaniels is offline   Reply With Quote
Old 04-17-2014, 10:43 PM   #5
Schluter KERDI-BOARD is Styrofoam with fiberglass cloth on both sides. It weigh's almost nothing.
Conventional would be 2 sheets of 3/4 plywood, or a mortar bed, or 3/4 plywood and 1/2 inch cement board. All are really really heavy.
I would say 10% or less of the other products.
This is the 1/2 inch version. 2 inch is special order at my store.
http://www.homedepot.ca/product/kerdi-b ... nd-/824220
Old 04-18-2014, 03:48 AM   #6
wow, sounds great, much appreciated!
Old 04-18-2014, 05:49 AM   #7
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
If you go to the website and punch in you zip, you'll get the local dealers within 110 mile radius.
Info very much appreciated by this neophyte skoolie, Nat.
Captain Obvious on deviantArt
Old 04-23-2014, 05:04 PM   #8
Your welcome folks. Glad to help.
I hope to see some pics in a build other than mine one day.
Old 05-28-2014, 01:36 PM   #9
Locutus's Avatar
Chassis: Super Coach II, 36 Ft. RE
Engine: Cat 3208T, MT643
Hey Nat,
At home I have Corian counter tops that are self supporting. That is, there is no backer board--the Corian is glued (with Silicone caulk) to the vertical edges of the cabinets themselves. I'm wondering if a Corian-type product (including Sile Stone, etc.) can be installed the same way in a bus, or if additional support is required due to motion and frame flex. Your comments?
Locutus
(Latin) loquor loqui locutus dep. [to speak (in conversation); to tell , say, declare, talk of].
Children drink kOOlaid, adults drink T.E.A.
Gallery: http://www.skoolie.net/gallery/v/Skooli ... +Coach+II/
Locutus is offline   Reply With Quote
Old 05-28-2014, 03:28 PM   #10
Originally Posted by Locutus
Hey Nat,
As long as the cabinets are rigid enough, it will be fine mounted the same way.
Most bus counter tops are small anyhow, so flex would be minimal.
Old 06-01-2014, 10:01 PM   #11
Thanks for sharing!!!
Follow our conversion:
Two Birds - 1992 Bluebird TC2000
WVO Powered!
viewtopic.php?f=9&t=467346
www.LiveLoveTravelDream.com
White99z is offline   Reply With Quote
Old 02-22-2015, 07:17 PM   #12
Coachwork: Gillig
Engine: Cat 3160
Nat,
Have you ever used the Kerdi Board on a vertical surface? We are creating our own shower stall and I wanted to use a faux concrete finish, but I'm concerned about the flexing during travel, so I'm considering tile. Can I use the Kerdi Board for the walls of my shower stall?
Becky
GilligusMaxibus is offline   Reply With Quote
Old 02-22-2015, 08:27 PM   #13
Yes.
I would back it with a half inch plywood, spanning the studs every 12 to 16 inches depending on the size of your tiles.
Larger tiles will crack with any flex, smaller are more tolerant.
I like big tiles, not small.
But how much did that bus cost new? roach711 Skoolie Conversion Projects 8 04-24-2019 11:47 AM
Montana Tile & Registration Henukaw Titles, Insurance, Registration and Money Matters 10 09-14-2016 09:06 PM
Tile floors in bus, has anyone done this? Almanzo Conversion General Discussions 5 07-03-2014 11:13 AM
Great site great info sources frank-id Everything Else | General Skoolie Discussions 1 06-09-2014 11:26 PM
Copper counter tops?! Lady Franklin Conversion General Discussions 4 10-08-2008 12:25 AM
