Old 07-16-2016, 07:32 AM   #21
Black water tank
I'm still in the process of finishing mine but Im using a 30 gal car wash soap barrel for my black tank , I used a 3in uni seal on top for the toilet drain into the barrel and another on the bottom for the tank drain to connect , installed a nipple in the removable cap to hook my vent to
Nhiggins is offline   Reply With Quote
Old 07-16-2016, 10:19 AM   #22
If you have not already installed the 3" Uniseal yet I will offer a couple of suggestions. I have installed a bunch of these and found a couple of things on the larger ones that help.
1- Use a low viscosity lube in the pipe & seal prior to assembly. I tried a number of "on hand" lubes. In my case they had to be suitable for potable water. I tried dish soap, laundry detergent, vegetable oil and finally Windex. The Windex worked best for me. Whoodathunkit?
2- Radius or bevel the ends that will be installed into the Uniseal. I happened to have a router table so I used a 1/4 round bit in the router and radiused the outside edge of the pipe.
3 - Eat your Wheaties.... The 1/2 & 3/4 seals are pretty easy to put together. 2-3 inch seals are a different story.....
Let us know how it comes out?
