11-25-2016, 01:27 PM
Massive modular synthesizer in bus?
So I have this $13,000 Synth and its im guessing 150 pounds with a solid walnut case. the bottom is Shipping weight: 120# and the top two are 30 and 40 pounds each so those will need their own rack but in hoped they attach to the bottom metal rails.
It splits into three parts the bottom being TWO MAN HEAVY.
I am wondering how do you mount metal bars to the side of a bus?
Example photo of what I want to build.
The bottom will be gymnasium foam to proect from shock. The sides will be tied down when moving and it should be able to come out if needed.
My question how do you affix the metal pipe so it wont pull out but wont go to the outside of the bus?
Yepp, 200 pounds!
11-25-2016, 04:24 PM
Engine: TE 444
Rated Cap: 12
And 100 pounds of patch cords ;)
11-25-2016, 05:24 PM
Engine: Navistar 7.6L
if your deadset on using a "pipe rack" as pictured.....
I would use the pipe flange at the top in pic on the wall.
Located on the vertical centerlines of two+ different ribs.
One hole above the other.
Two of these toggle studs per flange.
Support all the weight from the floor.
The upper pipe flange to the wall will only be holding it all stable.
11-25-2016, 05:56 PM
Good golly! What's the speakers look like?!?!
11-25-2016, 06:04 PM
In my bus, there are threaded sockets in the ceiling and two places at different levels for threaded forged eye bolts for securing cargo nets... Apparently they've drilled into some heavy metal rails to add the sockets. I haven't pulled any sheet metal yet to see... But, I'm guessing they look like these from Home Depot, and I've physically seen similar at my farm supply store in the trailer section.
11-25-2016, 08:34 PM
two 18 inch subs, 15 inch mains and some vintage JBL studio monitors from 1976.
11-25-2016, 08:41 PM
You'd be giving one of my buddies wet dreams...
He's all fascinated with his newest purchase, and I get to hear about it all the time.
Open Labs MIKO LX4 2.4GHz Core2Quad Keyboard Workcenter
Personally, I'm tone deaf... I have to use an app to tune my wind chimes
11-26-2016, 04:05 AM
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
Put a revolving dish on top and wear dark sunglasses. You'll be the "talk" of the campground!
11-26-2016, 09:26 AM
Can I buy the rails and make my own trays? Trays are $185! Rails are cheap! Then brace the bottoms yes with legs?
Do I have vertical studs in my bus? (I wish I had horizontal bitches!)
11-26-2016, 10:28 AM
yep, that e-track stuff would be ideal.
Can reconfigure your arrangement at will.
11-26-2016, 01:49 PM
I'd say Vertical E-Track between the windows, attach heavy lower shelf the size of lower synthesizer base, with two front legs to support the weight farthest from wall... Then you'd have the ability to cover synthesizer with a moving blanket, and strap it down for transport.
Bolt pipe flanges through flooring and pipe flange to bottom side of shelf.
You'd then have 4 or more points of support...
11-26-2016, 02:06 PM
Bare with me, I'm using primitive tools...
Black = Synthesizer
Yellow = bus
Green = E-Track
Red = bottom shelf and kicker
11-26-2016, 02:52 PM
on the other hand if you ran the e-tracks horizontal at the end of the green lines you would then be able to adjust the position of syn. to suit. Plus picking up the strength of more than one vertical rib per track.
11-26-2016, 03:08 PM
Year: 1987
Engine: 6.9L Diesel
Maybe you were joking, but just in case here's a picture highlighting my vertical studs. They are covered in black foam but you get the idea.
11-26-2016, 03:14 PM
that looks awesome but im afraid my skills will just be a tin can full of gear.
11-26-2016, 03:38 PM
I didn't get to say it in my Flintstone drawing.... But, the kicker would be a sheet of plywood cut to size, and turned horizontal, plus you could screw power strips to back side of it...
Say the bench is 5' long, then the kicker would be 5'wide and 3'tall..... The outer downward force of the front edge of bench transfers down to wall/floor joint.
