Old 11-25-2016, 01:27 PM   #1
Year: 83
Massive modular synthesizer in bus?
So I have this $13,000 Synth and its im guessing 150 pounds with a solid walnut case. the bottom is Shipping weight: 120# and the top two are 30 and 40 pounds each so those will need their own rack but in hoped they attach to the bottom metal rails.
It splits into three parts the bottom being TWO MAN HEAVY.
I am wondering how do you mount metal bars to the side of a bus?
Example photo of what I want to build.
The bottom will be gymnasium foam to proect from shock. The sides will be tied down when moving and it should be able to come out if needed.
My question how do you affix the metal pipe so it wont pull out but wont go to the outside of the bus?
Yepp, 200 pounds!
Jaybus2 is offline   Reply With Quote
Old 11-25-2016, 04:24 PM   #2
Engine: TE 444
Rated Cap: 12
And 100 pounds of patch cords ;)
Old 11-25-2016, 05:24 PM   #3
Engine: Navistar 7.6L
if your deadset on using a "pipe rack" as pictured.....
I would use the pipe flange at the top in pic on the wall.
Located on the vertical centerlines of two+ different ribs.
One hole above the other.
Two of these toggle studs per flange.
Support all the weight from the floor.
The upper pipe flange to the wall will only be holding it all stable.
DoubleO7 is offline   Reply With Quote
Old 11-25-2016, 05:56 PM   #4
Good golly! What's the speakers look like?!?!
Old 11-25-2016, 06:04 PM   #5
In my bus, there are threaded sockets in the ceiling and two places at different levels for threaded forged eye bolts for securing cargo nets... Apparently they've drilled into some heavy metal rails to add the sockets. I haven't pulled any sheet metal yet to see... But, I'm guessing they look like these from Home Depot, and I've physically seen similar at my farm supply store in the trailer section.
Old 11-25-2016, 08:34 PM   #6
Year: 83
two 18 inch subs, 15 inch mains and some vintage JBL studio monitors from 1976.
Old 11-25-2016, 08:41 PM   #7
Smile
You'd be giving one of my buddies wet dreams...
He's all fascinated with his newest purchase, and I get to hear about it all the time.
Open Labs MIKO LX4 2.4GHz Core2Quad Keyboard Workcenter
Personally, I'm tone deaf... I have to use an app to tune my wind chimes
Old 11-26-2016, 04:05 AM   #8
rossfree's Avatar
Coachwork: Chevy
Chassis: Ward?
Engine: 8.2 liter ?
Rated Cap: 24 Passenger
Put a revolving dish on top and wear dark sunglasses. You'll be the "talk" of the campground!
rossfree is offline   Reply With Quote
Old 11-26-2016, 08:38 AM   #9
prof.fate's Avatar
e-track is what all cargo trucks use, and self tapping screws into the vertical 'studs'.
Did that in my cargo trailer - nothing penetrated the exterior.
They make all kinds of attachments for e-track - i've made shelving, hung/attached things that far outweigh your synth.
grainger, harbor freight carry some things, or look here
Tie Down Anchors E-Track Parts Trailer Cargo Control | etrailer.com
shelving and other ideas -
https://www.google.com/search?q=e+tr...w=1680&bih=931
prof.fate is offline   Reply With Quote
Old 11-26-2016, 09:26 AM   #10
Year: 83
Can I buy the rails and make my own trays? Trays are $185! Rails are cheap! Then brace the bottoms yes with legs?
Do I have vertical studs in my bus? (I wish I had horizontal bitches!)
