Old 11-20-2018, 05:17 PM   #21
I never needed a bender.. I did baby steps and worked sections of my lines slowly and ended up with good bends. just dont get in a hurry and do minor bends over a distance of line and slowly get tighter each time.. dont try to just make a 90 with a single bend..
Old 11-20-2018, 08:19 PM   #22
david.dgeorge07's Avatar
Chassis: Thomas
Engine: CAT 3126
Reading this post brings back a ton of memories! Fun times!
I used different sizes of paint cans to help bend the copper. There is a learning curve. Be gentle and it goes fine. If it kinks you can heat it some with a torch and squeeze/ease it back.
If you any of you need help with the initial vacuum and charge I have all the stuff and epa section 608 certification.
My dual mini splits are one of the favorite things about my bus. One did have a very slow leak, but seems like it was just a flare nut that was not tight enough.
I hung mine between the frame rails and they have operated with no trouble both stationary and over the road.
I have doors in the skirt I can open for more ventilation, but they seem to work fine either way.
My Build Thread:
http://www.skoolie.net/forums/f11/4-...ner-18205.html
Old 11-20-2018, 10:28 PM   #23
Ninjakitty's Avatar
Engine: 6.6 New Holland Diesel
Rated Cap: 60 kids, 10 window
Originally Posted by Jolly Roger bus 223 View Post
There is no such thing as a precharged linesets? There are preset lengths that are already factory cleaned and sealed that have the proper flare connector and nut on them.
But... But... Mine came pre-charged. All I had to do was connect the lineset to the compressor and hook up the electric...
Nick
Old 11-20-2018, 10:30 PM   #24
Ninjakitty's Avatar
Originally Posted by BlackJohn View Post
There is a way to bend lines of this type without kinks by sliding a long tightly coiled spring over the lines, a tad bigger that the line diameter.
This may explain the spring around my lineset copper. However, nothing in the instructions that said anything about moving the spring.
Nick
Old 11-21-2018, 12:50 AM   #25
Chassis: Thomas
Engine: CAT 3126
Your unit or your lines? Normal for the unit to be charged, and the unit will work albeit less than ideal if you just connect the lines and release the refrigerant.
The lines were sealed with refrigerant inside?
My Build Thread:
Old 11-21-2018, 07:21 AM   #26
Ninjakitty's Avatar
I bought this. Everything comes pre-charged.
https://www.homedepot.com/p/ClimateR...SACH/304624913
Nick
Old 11-21-2018, 07:22 AM   #27
Thanks for the input boys. It's just that these units are not popular up here I guess, hardly ever see any for some reason.
I do admire those who can install tubing such as this or for instrumentation purpose, it sure is an art to behold in both copper and stainless. Unbelievable installations with many back to back 90 degree bends in parallel runs etc. Just blows my mind how good these guys are at their trade.
Old 11-21-2018, 07:42 AM   #28
Chassis: Thomas
Engine: CAT 3126
Wow! That’s cool!
My Build Thread:
Old 11-21-2018, 09:38 AM   #29
ComfortEagle's Avatar
Coachwork: Gillig
Chassis: Phantom
Engine: Cat 3208/Allison MT643
Quick disconnects; brilliant.
Here is a pic of the indoor unit mocked up.
Rick <>< - Comfort Eagle (Bird Strike) - Solar/Batteries - Seat - Door - Dash - Mini Split - Fuse Box - Wood Stove
ComfortEagle is offline   Reply With Quote
Old 11-25-2018, 08:01 AM   #30
Chassis: International 3000
Engine: DT-466
Rated Cap: 64 passenger
Has anyone come up with anything for mounting a condenser on a bus without giant storage boxes underneath?
When we started our conversion a mini split was the plan. However, after talking with an HVAC guy we have worked with a few times, he seemed to think the condenser’s scroll compressor would be damaged if used while bouncing down the road. Has anyone experienced this?
I’d love to replace my window unit, last time I took it out I dropped the freaking thing on my head and still had to go down with it so it didn’t smash to the ground. Plus it looks kind of bad sticking out of an emergency exit. Works well though.
Charlesreid42 is offline   Reply With Quote
