Old 08-16-2016, 09:44 PM   #31
Does a lot of insulation help with the AC issue?
I also plan to remove a good portion of the windows and replace the remaining ones with RV windows.
meldy is offline   Reply With Quote
Old 08-16-2016, 10:55 PM   #32
Yes. Insulation helps a lot with both heating and cooling.
BusFiend is offline   Reply With Quote
Old 08-17-2016, 07:41 AM   #33
Chassis: International S3800
insulation and tinted RV windows will help you out alot for being parked... if your bus is a conventional and has a lot of engine heat while driving, you will have to seal off the cracks and crevices around the doghouse, wire harnesses, hoses, etc that go fro mthe engine bay into the bus cabin...
Old 08-18-2016, 01:42 AM   #34
Any chance you can send me all that information please? Any other ideas and information you have would be cool to!
Scope88 is offline   Reply With Quote
Old 08-18-2016, 02:21 AM   #35
Yukon John's Avatar
Chassis: MVP/EF
Engine: Caterpillar 3126
Rated Cap: About 40
That's how I bought mine😉
Yukon John is offline   Reply With Quote
