Old 12-14-2008, 11:15 PM   #1
Blackhorn Buses's Avatar
Rated Cap: 40
Need advice concerning A/C
I’m turning my 96 Bluebird into a party bus. I need some advice on the cheapest way to get an A/C system installed. It’s necessary for the A/C to work while driving. The cheapest quotes I’ve received so far have been way out of my budget. $8000-$12000. Any suggestions
Thanks Matt
Blackhorn Buses is offline   Reply With Quote
Old 12-17-2008, 08:16 PM   #2
GoneCamping's Avatar
Re: Need advice concerning A/C
Probably the most cost effective method will be something like described above, one or two roof top RV style A/C's (can get them on ebay for around $300-400 each plus shipping), and a generator large enough to power them, you'll need around 5-7 kw gennie for 2 of them. Using a battery bank, high output alternator and a high powered inverter might also work, but the generator would likely be cheaper...
One other option that plays on the Generator idea, would be to pick up a belt drive generator power head (Harbor Freight sells them for around $300), and find a way to mount it to the bus engine and let that power it....
*Cliff*
...Your home has brake lights
1994 Jeep Grand Cherokee
Chesapeake, Virginia
GoneCamping is offline   Reply With Quote
Old 12-17-2008, 08:26 PM   #3
lapeer20m's Avatar
that won't work while driving. A generator head like that would have to run exactly 3600 rpm (or 1800 rpm for a more expensive one) When the generator head spins faster/slower than thsi it no longer makes 60 hz 110 volts.
Advice newbiefamily Conversion General Discussions 11 03-29-2014 08:57 AM
Need advice please chev49 Conversion Tutorials and How-to's 2 07-14-2012 08:44 AM
Bus advice gbstewart Conversion General Discussions 5 02-01-2012 08:54 PM
New and Looking for Advice bm1253 Short-Bus Conversion Projects 12 04-18-2009 12:19 PM
Advice lunadog60 Everything Else | General Skoolie Discussions 1 09-04-2008 12:18 PM
