Old 01-24-2007, 10:49 AM   #1
Shrtbusdrvr's Avatar
Need advice for hooking up my electricity
I have BIG plans for my tiny bus. first off i have no ac in my bus but i have a window unit that i would really like to be able to run while driving. what is the cheapest safe way to do this?
18' 92 GMC Vandura 6.2 Diesel
http://www.customfoamworks.com/bus/
Shrtbusdrvr is offline   Reply With Quote
Old 01-24-2007, 11:45 AM   #2
lapeer20m's Avatar
if you have a big enough inverter and alternator that is the way to go while driving.
Old 01-24-2007, 12:58 PM   #3
Steve's Avatar
Thats the way my A/C works.
Old 01-24-2007, 01:09 PM   #4
the_experience03's Avatar
Just how big of an alternator do you have, Steve? 10 amps@120vac (about average for a smaller A/C)=100 amp@12vdc. That doesn't leave much power for anything else
Old 01-24-2007, 01:17 PM   #5
Steve's Avatar
Oh forgot to mention I have a giant bank of batteries to supplement.
A short bus probably doesn't have a very big alternator so you probably cannot run your A/C on that alone.
Old 02-02-2007, 04:03 PM   #6
Assuming he has quite the supply of deep cycle batteries, he might pull it off if he insulates the beejezus out of the short bus. Assuming a duty cycle of maybe 50%, a little better than a 60 amp continuous draw might do it. Just don't try running the lights or blinkers or cd player at the same time.
Also, you could strap a windmill to the roof!
pete c is offline   Reply With Quote
Old 02-02-2007, 08:57 PM   #7
I keep forgetting that you have that power-up-Las-Vegas-in-the-event-of-nuclear-winter battery bank in your bus.
My alternator is only rated to 130 amps while I see some of the 22SI Delco alternators finding their way into much smaller trucks nowadays are rated to 225 amps and more so physical size of the vehicle may or may not play a big role in the size.
A person could always just add another alternator....
Old 07-17-2007, 09:13 PM   #8
Year: 1950
Coachwork: don't know
Chassis: cheverolet
Engine: to be determined
Rated Cap: 28
Re: Need advice for hooking up my electricity
how about adding a extra alternator to motor preferably a gm 1 wire alternator. and run the invertor off of that. that way you have the full attention of the altenator to run the invetor and you will not interfer with the vehicles charging system
dale
delbertinie is offline   Reply With Quote
Old 07-17-2007, 09:18 PM   #9
With a 3 wire alternator he could put a toggle switch on the field voltage wire and turn the AC on and off from the driver's seat.
Old 07-17-2007, 10:10 PM   #10
Year: 1950
Chassis: cheverolet
Rated Cap: 28
great point I was just thinking of simplicity. wayne we keep running into each other ha
Does a diesel run without electricity? PDBreske Mechanical and Drivetrains 5 01-27-2012 10:10 PM
Hooking up the heater to a second radiator? Steve Conversion General Discussions 3 07-12-2009 09:24 AM
hooking air compressor hose to air tank? TikiBus Everything Else | General Skoolie Discussions 3 11-02-2008 09:10 PM
Electricity question. crazycal Conversion Tutorials and How-to's 1 07-14-2008 09:26 AM
Hooking up stereo Chfsfn2 Conversion Tutorials and How-to's 1 08-31-2004 10:09 AM
