Old 03-30-2010, 07:33 AM   #11
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Re: need help with windows!!!
I just wanted to add a piece of information to this thread. I used a crowbar to pry out my first window last night. I was careful not to damage the inside metal (even though it's getting covered with insulation). I just started working it on the sides and prying it back and forth, then eventually on the top the metal hung over the window a little bit but I just muscled it out. There is some gooey substance to hold it in place, but if that's a problem you could always use a propane torch or heat gun to melt it and make it easier.
Rutgers tailgating bus http://www.skoolie.net/forum/viewtopic.php?f=36&t=5545
RUskoolietailgater is offline   Reply With Quote
Old 03-31-2010, 04:46 PM   #12
lornaschinske's Avatar
Rated Cap: 89
Originally Posted by emberglow
... does anyone know how to get the black sealant off after 25 years?
I've used Lacquer thinner on our Class C's black goo (previous owners). Use stripper chemical gloves on your hands. Lacquer thinner is nasty stuff.
Fulltime since 2006
Old 04-01-2010, 08:17 AM   #13
Coachwork: Chevy
Chassis: Bluebird
Rated Cap: 16
Try a propane torch or a heat gun to heat it up and make it soft. Or use a crowbar and try to pry it out?
windows Zephod_beeblebrox2 Conversion General Discussions 8 12-07-2014 09:33 PM
RV Windows Stu & Filo. T Conversion General Discussions 1 01-21-2014 10:27 PM
Screening original windows and installing RV windows skoolz out Conversion Tutorials and How-to's 3 10-27-2010 01:54 PM
Windows TygerCub Conversion General Discussions 15 10-14-2009 10:49 AM
How Many Windows To Tin Over? CVanDamme Conversion General Discussions 3 12-14-2006 07:02 PM
