Old 08-20-2016, 10:10 AM   #1
Yukon John's Avatar
Chassis: MVP/EF
Engine: Caterpillar 3126
Rated Cap: About 40
Newbie... Needing ideas!
Okay we just got our schoolie and we cut most of the seats out and am in the process of sticker removal and painting .,,, so far so good! However, I need some ideas.
1. Any uses for the little stop sign flipper. It is air driven and seems to work fine.... I hate to just chuck it when it could probably be used for something.
2. Wheel chair lift???! Any uses other than just a lift.
I'd sure appreciate any good ideas. Thanks
Yukon John is offline   Reply With Quote
Old 08-20-2016, 03:27 PM   #2
johnbloem1974's Avatar
Coachwork: Crown by Carpenter
Engine: DT 466e/MT 643!
Rated Cap: 16
So, we were originally going to remove our lift, but then realized it has come in soooo handy! As we were doing our build it was a lifesaver for loading heavy/bulky items into the bus. As we now use our bus, it is great for the heavy cooler full of beer! We also have been using it as a table or cooking area at campsites/etc. just lower it to the level you need and its great!
johnbloem1974 is offline   Reply With Quote
Old 08-20-2016, 09:37 PM   #3
Carytowncat's Avatar
You got a motorcycle lift in yours? nice!
Remember; if you sit around it, put a brace/ jack stand underneath it in case it fails and falls. Knees and legs are no match for falling steel.
Old 08-21-2016, 01:05 PM   #4
Yukon John's Avatar
Chassis: MVP/EF
Rated Cap: About 40
Great idea on the cook top/table! Thanks!
Old 08-21-2016, 01:59 PM   #5
Yukon John's Avatar
Chassis: MVP/EF
Rated Cap: About 40
Well it's a little short for a bike...narrow for a 4wheeler.... But that's good advice on the safety issue. Thanks!
Old 08-21-2016, 05:08 PM   #6
Rated Cap: 16
we don't really sit around it, but the way ours is built - even if it failed, it wouldn't fall though....
Old 08-21-2016, 06:44 PM   #7
New2Skool's Avatar
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
A guy in my state removed the lights from his stop arm and primed over everything and wrote the name of his bus on it.
D.L. Jones III
"The Independence"
98 International
New2Skool is offline   Reply With Quote
