You basically have the idea. there is no OPD valve on tanks bigger than 7 gallons. That is 20 lb BBQ thing. Unless your in Canada then the weigh the tank to full so they don't need the valve.
You would not take the tank out to refill you would run a remote filler hose. the tank is permanent mount.
I say use the 100lbs because there just so dam cheap new and its so easy to modify with not being used or filled yet. I have drilled welded different valve positions in and welded tanks together and added headers to them. There only 150 PSI. Those hundreds are really nice if you use propane at home. its usually a buck a gallon extra to have the truck come fill it. I just toss a couple in the truck and have them filled and come home and use a hose i made to connect it to my 250 tank. stand the tank upside down and it transfers into the 250 in just a few minutes with the vent on the 250 tank open to allow the fluid to move. Then I use the same hose to fill my car tanks. You don't need pumps to move propane around. Plus with 40 gallons on board you can run it on your bus engine when you need some extra power. just need a ball valve with a 1/4 fitting and a EGT to set the temp or mixture? its really the temp.
The stuff is so amazing i think i'll put a flame thrower kit on the tail pipe.
Maybe dump it through a tail gunner
