Old 03-13-2016, 05:52 PM   #1
Chassis: international
newbie needs help with electrical
Hello everyone, I am new here but have been reading posts for months, been dreaming about my bus for about 3 years. I finally got to buys my bus about a month ago. I got a 2002 with a DT466. I have NO CLUE about electrical so please speak to me as if I were stupid. I know what I want but I am not sure how to do it exactly, so I want to put in a shore line, and a 4000 watt inverter. I want the shore line to power when hooked up and then inverter to power when not. I want the alternator to charge my house batteries when they need it but I want to keep starter batteries and house batteries separate... can someone please give me some kind of sematic to show exactly how the wires would run from item to item including the breaker box. I DO NOT WANT A GENERATOR OR SOLAR POWER. is this set up possible if I am plugged in or driving at all times?? Thanks for your help! Misty
karma8282 is offline   Reply With Quote
Old 03-13-2016, 06:16 PM   #2
roach711's Avatar
Rated Cap: 19
Here's a recent thread on bus electrical:
http://www.skoolie.net/forums/f13/el...ing-13059.html
The Roach Motel
Old 03-13-2016, 07:37 PM   #3
Yes I seen that post but I got confused when I read all the comments and someone said to use a converter not an inverter.
Old 03-13-2016, 09:40 PM   #4
roach711's Avatar
Rated Cap: 19
A converter takes 120v AC shore power and converts it into 12v DC. Most converters also incorporate a battery charger too. The better ones are three stage chargers which do a much better job of keeping batteries charged than the older/cheaper single stage chargers.
An inverter takes 12v DC from the battery bank and makes 120v AC to power stuff that you could normally plug in at home.
To confuse things a bit, you can also get an inverter/charger (also known as a standby inverter). These units combine an inverter and a converter/battery charger and are wired to both shore power and the battery bank. Electronics inside the unit monitor the shore power line and automatically switches to battery/inverter power when shore power is unplugged. These are pretty expensive but do a good job of automatically switching between shore power and battery power.
Getting 12v and 120v power to peacefully (and safely) co-exist is the hardest part of the bus conversion puzzle. Boondockers usually try to be light energy users and typically use small inverters and smaller battery banks. Campground campers tend be set up much more for 120v AC and use the battery bank/inverter to power stuff while driving.
The Roach Motel
Old 03-13-2016, 09:55 PM   #5
Yes, I have been looking at inverter/converter/battery charger all in one... That is the way im going to go I believe. Smartest way for us as we are camping ground people. And with 5 kids (teens) there are always phone chargers, laptops, t.v., an Xbox, fridge, fans and whatever else going. Lol.
Old 03-13-2016, 10:12 PM   #6
Bare with me
OK so if I use the 3in1 it should go like this?
Shore line
To
50amp inlet
To
3in1 inverter/converter
To
Ac breaker box, remote panel battery bank
To. To nothing. To
120v outlets. DC fuses
To
12v lights, 12v sockets
Then from right side it goes
Alternator to
Starting batteries to
Relay to
Battery bank
Old 03-14-2016, 07:57 PM   #7
Got it, thanks roach, u r awesome. Ordering parts tonight and we are on spring break next week so I will let ya know how it goes... Lol
Old 03-21-2016, 11:43 AM   #8
Wow Misty, it sounds like you are in better shape than us!
Great information in this thread, thank you Misty and roach.
Is it possible to do a similar setup what Misty has suggested, but to incorporate a generator into the mix as well? A generator as an alternative to the alternator charging the battery bank?
Additionally, what should I look for in a battery relay?
Plantresilience is offline   Reply With Quote
Old 03-21-2016, 01:23 PM   #9
If u click the link in Roach's first reply u will find a schematic that shows it with a generator. I went to a local rv shop and found a very helpful man who pointed me to a relay. They also sold an inlet, distribution panel, inverter/charger, shore power lines, and other items. Good luck, we are going to try to hook it all up this coming up weekend. Will let you know how it goes.
Old 03-21-2016, 10:48 PM   #10
OK, so I finally figured out how to get my picture uploaded but only to my profile page so if y'all wouldn't mind going to take a look and let me know what ya think I would greatly appreciate it! If ya see any problems please let me know. Thanks
electrical, newbie
