Old 06-13-2010, 12:13 PM   #21
Elliot Naess's Avatar
Engine: 5,9 Cummins
Re: Old floor heaters
Originally Posted by Alisongrrl
There is a small copper pipe that runs into the engine. It is connected to a dial. I am not too sure what this line contains and I do not want to disconnect it and find out it is something bad the hard way. Anyone have any ideas what this contains??
I am attaching a link to pics for reference.
http://www.facebook.com/photo.php?pid=5 ... 1228863850
Try to follow this line and find out where it goes. I have a hunch it is not related to the heater. Could be compressed air. Looks like a shut-off solenoid and a pressure- or flow- regulator. Air operated door?
Elliot
Old 06-13-2010, 04:41 PM   #22
jkindt's Avatar
Year: 1981
Chassis: Ford B-600
Engine: Ford 370 Propane
Rated Cap: 48
Originally Posted by Seeria
This might be slightly off topic but
Is there some type of pen or tape, some way to label these hoses that is safe? Wouldn't want a hot hose to start a fire 'cause I put the wrong material-tape-whatever on it just so I can remember what is what. Old age... *sigh*
I would just write on them with a regular Sharpie marker. Even if your engine was overheating the hoses should not get over 200 degrees. If they do, you will have more problems than just the writing burning off. Most engine thermostats are either 160 or 180 degrees and there will be temp losses from the engine to the point where your heater hoses are inside the bus.
Old 01-18-2011, 11:20 PM   #23
Engine: T444E 3800
Rated Cap: 34
My heater hoses ran from the engine block (both had shut off valves) to a heater core near the driver then to a separate diesel fired auxiliary heater and then to the rear of the bus under a seat. I removed the auxiliary heater from the side compartment and the rear heathttp://www.skoolie.net/forum/postin ... &t=4444#er core. I reattached the hoses from the engine block so that they now only go into the heater unit near the driver seat. I still have heat and I was able to sell the rear heater core and the aux. pump/heater unit for $600.00! Wow... almost like my bus was free!
Chuck Gbur
Go Bucks...
http://www.skoolie.net/gallery/index...es/PAIR-A-DOCS
cjgbur is offline   Reply With Quote
Old 07-24-2011, 05:32 PM   #24
Re: Old floor heaters - underfloor heat mod?
Question - Could the stock heating system be used to provide heat for an underfloor (radiant) heating loop like ones put into homes? Seems like this would be a way to free up space where ther original heater were and should also be more efficient since the heat tubing would be throughout the floor and thus spread the heat evenly.
dgorila1 is offline   Reply With Quote
Old 07-24-2011, 11:46 PM   #25
lornaschinske's Avatar
Rated Cap: 89
The heat system in the buses are hydronic with fan forced heat exchangers.
You would need to heat the fluid (usually anti-freeze) with a heater (think water heater.... like an old 6 gallon LP Bowen/Atwood) and put a pump inline that is for circulating hot water/fluids (like an El Sid or similar). You can keep the original heat exchangers and build a duct system to distribute the heated air. Hey, I just described how we will do our heat system.
Substitute (or include) PEX lines under the floor to the system and insulate . Look at outfits like Radiantec figure out what type of system you will install and download their DIY manuals A closed system is the easiest to install but will require a dedicated water heater. You can install a valve so that you can use the heating system to preheat your diesel engine or use the engine to heat the fluid while traveling down the road (when you can't use the water heater). You are building your own Aquahot. Aquahot manuals
Fulltime since 2006
Old 10-02-2016, 01:37 AM   #26
chad.nuesmeyer's Avatar
Engine: Cummins 5.9 (24v)
Rated Cap: 66 Passenger
Originally Posted by lornaschinske View Post
The heat system in the buses are hydronic with fan forced heat exchangers. [/url]
Do the heaters sitting on under the seats have any type of pump to facilitate the flow in the hydronic system? Or do they rely on the hydro-dynamics of heating and cooling to cause them to flow? The reason I ask, I am curious about swapping out the stock 'under seat' heaters for a radiant baseboard heater, common in residential construction. Something like this: https://goo.gl/v2SEOh
However, if that works then I don't see why you wouldn't be able to run some pex-radiators under the floor. I am thinking something like this: https://goo.gl/1Q2K6o
For right now I am thinking this would only be used for driving heat. When stopped we would use propane forced air heat.
Thoughts?
chad.nuesmeyer is offline   Reply With Quote
Old 10-02-2016, 09:05 AM   #27
Chassis: International S3800
the bus heaters use the bus water pump to facilitate flow... some busses also have a small electric boost pump (your dash may have a switch that says boost pump).. this is to help with increased flow to the heaters...
you do gain some reserve heat from the residual in the engine block to turn on the boost pump and one of the heater fans when the engine has just been shut down.. you'll get heat for a while( hour or 2) depending on how cold it is outside..
for PEX under-floor heat you will likely want to do some type of temperature controlled Bleed-Loop.. (a coolant loop with its own circulation for the floor.. with a simple bleed inlet of hot coolant from the engine that will maintasin a constant floor loop temperature.. the floor loop would use its own pump..
reason being you dont want 180 - 200 degree coolant under your floors.. the bleed-in allows you to circulate a loop of cooler (80 - 100 degree) coolant under your floors and simply Mix-in a slight amount of the hotter coolant and circulate it around.. this maintains a nice even and tempered temperature for your floors..
Old 10-02-2016, 10:52 AM   #28
FlyboyHPD's Avatar
I have that exact switch in my AmTran. I won't be using the switch so plan to remove it and the wiring. Where is the pump typically located so I can remove it as well?
1999 International AmTran, DT466E, MD3060
https://flyboyrv.wordpress.com/
FlyboyHPD is offline   Reply With Quote
Old 10-02-2016, 11:38 AM   #29
the pump is under the hood... and is also useful in burping air out of the cooling system if you have a loss or are flushing.. it hurts nthing to keep it, but its pretty easy to find, will be on one of the heater hoses near the engine and have usually an orange and black wire going to its motor..
it also facilitates better circulation to your driver heaters and defrosters.. which you will want to keep unless your bus is a tiny home to be parked and not driven.
Old 10-02-2016, 03:34 PM   #30
FlyboyHPD's Avatar
Hmmm, in that case I guess I will keep it. Some fool painted the radiator plastic overflow container so I can't see the "cold" full level anymore. Is there anything I can use to remove the paint that won't eat into the plastic?
Help me take my heaters out. jjhomeonewheels Conversion Tutorials and How-to's 7 08-27-2017 10:13 PM
Stock Heaters??? dirtygoat Conversion General Discussions 2 08-05-2010 11:48 AM
Who has kept their rear heaters? M1031 Conversion General Discussions 11 07-02-2010 09:46 AM
heaters?? gbstewart Conversion General Discussions 0 05-19-2010 06:01 PM
Heaters How can i be safe when using propane powered heaters andybus9 Conversion General Discussions 1 01-12-2004 01:01 PM
