Old 07-18-2016, 12:46 AM   #1
Year: 1980
Chassis: c70
Engine: 8.2l dd
onan 4.0bfa generator inslation
ok so i have bought a onan generator and am about to install it ether under drivers seat or in front of the pasnger tire on rear of the bus the inslation on the gen says the has to have 5 inch above the gen to the top of the gen box but i am thinking that it will be hanging down to low i was thinking i could raise it up and use some 2 inch rock wool board in between the gen and the chassie and maby add a fan to help pull more heat out of it just wandering what you all think the bus is a 1980 captner bus chevy 8.2l dd i am adding the genrator to as a back up to the 500w sloar system
michellep is offline   Reply With Quote
