Old 07-04-2012, 09:00 PM   #1
Year: 1977
Coachwork: Chevrolet
Engine: 366
Onan generator output
So my onan generator has a 20 and 30 amp 110 volt output. Can I combine this to be one 50 amp breaker somehow?
Soundman1 is offline   Reply With Quote
Old 07-04-2012, 10:30 PM   #2
opus's Avatar
Chassis: All-American R/E
Re: Onan generator output
No.
Old 07-05-2012, 08:46 AM   #3
you should post your generator specifications for help with it...
Old 07-15-2012, 04:06 PM   #4
Year: 1977
Engine: 366
Here are some pictures of the unit. Trying to get all 50 amps from this unit so we can run both ac nits. They draw 13 amps each. My assumption is that the generator head is putting out all 50 Amos and then it gets split to 2 breakers. Can I intercept it before the breakers and send to one 50 amp breaker? Output wiring is one ground two hots and two neutrals
Old 07-15-2012, 05:16 PM   #5
If it has 2 seperate breakers;Why can't you run 1 on the 20amp breaker and run 1 on the 30 amp breaker plus 10 amps of lights etc?
Old 07-16-2012, 08:23 AM   #6
Year: 1977
Engine: 366
because i want to run everything off of one 50 amp panel so that when i use shore power i dont have to do anything and it is a simple process. 50 amps from genny, 50 amps from shore both feed into transfer switch which feeds panel
Old 07-16-2012, 09:53 AM   #7
i dont have a 6.5 emerald genset, but if the output wires that go to the two circuit breakers are one set of wires, then you can run them to one 50 amp breaker. i assume that it is made this way, cause the other way would require two sets of windings in the generator - one for each of your circuit breakers.
this can be looked up online of course, my guess is that you can just have one 50 amp circuit breaker instead of the two other ones. you have enough amps to run your ac units... i have a 4000 watt onan, and it will run my two ac units, and one is a 13.5 and the other 8000.
i cant tell from your wiring picture, but if it were mine, i would look to see if one set of wires feeds both breakers...
Old 07-17-2012, 06:47 PM   #8
Year: 1977
Engine: 366
Here is a better picture
So the black wires are the breaker output. The white are input. There is a seperate wire to each breaker from "inside" the generator, but they are also jumpered together. So would I just bring both of these to my 50 amp breaker?
Old 07-17-2012, 07:16 PM   #9
are both the black wires hooked together like the white ones? if so, only 1 set of wires is running to the genset like mine is. i took the circuit breakers out of mine and just put one large one in line before the automatic switch over switch.
i also changed some other wiring in the panel, as some clearly isn't needed for operation or auto shut down.
Old 07-17-2012, 08:29 PM   #10
Year: 1977
Engine: 366
My two blacks are seperate. They appear to be the "output" of the breakers
non Onan generators in the bus The Nebuchadnezzar Alternative Fuels | Electric, Propane, Wood Gasification, etc. 4 03-23-2015 12:24 PM
Onan problem chev49 Conversion General Discussions 0 05-01-2012 09:46 AM
Onan 4.0 BFA opus Classifieds | Buy, Sell, Swap 1 09-28-2010 02:56 PM
Thomas Bus normal alternator output mfrederick Conversion General Discussions 3 09-16-2009 12:54 AM
Onan generator swhite832 Skoolie Conversion Projects 2 08-14-2009 11:46 AM
