Old 02-06-2017, 12:42 AM   #1
overall dimension
Hi there folks. Im Really interested in converting a bus or buses of my own. I've never done it but im some what fixated on all the potential things I could do with and to a bus. I've been looking around to see if I can find any measurement for the insides/ over all specs, so I can be draw out designs fer mah tinkerins' lol if anyone can help me I'd really appreciate it.
TheLunge is offline   Reply With Quote
Old 02-06-2017, 08:33 AM   #2
Rated Cap: 65 pax
Hi! Welcome to our forum
Measurements vary from bus to bus. If you have a gander around the site, using the search button above, you should be able to find some measurements. My 2003 International 65 pax bus has an inside measurement, from the back of the drivers seat to the back door of ~27 feet and it is 7.5' wide.
Sandi
www.thismidwifetravels.com
WanderWoman is offline   Reply With Quote
Old 02-06-2017, 10:00 AM   #3
Engine: T444e
Rated Cap: 35
My 2001 International Amtran 34 passenger is 7.5' wide and 14'3" from back door to the steps. Interior height is 76".
bstewrat3 is offline   Reply With Quote
Old 02-08-2017, 02:48 AM   #4
fast thanks
that was a quick reply! thanks guys. What should I search for? bus dimensions?
First I'll find the model of the bus Im thinking of.
Old 02-08-2017, 08:21 AM   #5
Dapplecreek's Avatar
Rated Cap: 44 or 66? 11 rows
Also try google search and put in site:skoolie.net as one of the search terms. It often works better.
A couple of folks here measured their 2000 (or so) International 65 passenger conventional and the clear area at the far back (behind the wheel wells) appears to be 7' 6" for the width and 9' 2" front-to-back. More passengers = more room there; fewer passengers = less room, of course.
Dapplecreek is offline   Reply With Quote
Old 02-08-2017, 09:24 AM   #6
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Mine's about 37' bumper to bumper, 78" interior height, and 7'6" wide
Captain Obvious on deviantArt
Old 04-10-2017, 12:14 PM   #7
Brewerbob's Avatar
Engine: 8.3L Cummins ISC 260hp, AT643, 4.44 rear
'99 Bluebird, 84 passenger, 13 (window) row, rear engine bus 39' 4" from front glass to rear glass.
