Old 09-23-2007, 03:31 PM   #11
Coachwork: Chevy
Re: Painting a bus
Could someone give me some ideas on the type of paint I need to repaint the INTERIOR of our school bus? Outside is painted bright lime green, inside needs some help!
Lime-a-Zine is offline   Reply With Quote
Old 09-23-2007, 08:59 PM   #12
phillbus914's Avatar
Re: Painting a bus
I just used a gallon of rustoloum and rolled it on. It's held up fairly well for the past 3 years, the only place's that need touching up are where it's been scratched by something and by a few windows where moisture builds up has a little rust showing though. I'll probably grind it clean and reapply paint...
meh someday.
My Old Bus :(
Old 09-24-2007, 08:25 AM   #13
lapeer20m's Avatar
Re: Painting a bus
i made the mistake of painting my ceiling once without doing any sanding. in a year or so all the paint was cracked and peeling. The moral of the story....make sure you do it right the first time.
Old 11-16-2007, 11:11 PM   #14
davido's Avatar
Re: Painting a bus
From my experience and sportyrick's, stay away from alkyds. He's exactly right, they don't stick worth a damn. Which bites it because I'll probably end up stripping it all off eventually and do it all over again with enamel.
davido is offline   Reply With Quote
Old 11-18-2007, 08:55 AM   #15
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
Re: Painting a bus
Hi guys and Gals,
I know it's been a long time since I posted, but I haven't forgotten about you.
Well, anyway, Hot Rod Magazine recently roll painted a 62 Falcon and wrote a how-to for roller painting, with Rustoleum.
The link is: http://www.hotrod.com/techarticles/b...job/index.html
Check it out and see what you think.
BTW. the title is "The $98 Paint Job."
Roasting8
Roasting8 is offline   Reply With Quote
Old 01-02-2008, 10:57 PM   #16
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
Re: Painting a bus
for the amount of bodywork those guys did to the car and the amount of labor involved in rollering the car i will be spraying our bus that is too much labor i like hearing that cheap clearcoat works on the tremclad paint i painted a 65 chevy [pickup orange and it looked great but it faded bigtime very quickly it did stick very well though i used a cheap gun and it worked well tooo big buks to paint with automotive paint!
Old 01-03-2008, 11:10 AM   #17
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Re: Painting a bus
Well, if you've got more time than money, this would might be the way to go. If you spray more paint on yourself than you get on the bus, this might be the way to go. If after you spray paint things and your paint runs more than the runners in the NYC marathon, this might be the way to go.
Old 07-10-2008, 02:28 PM   #18
Engine: DTA360
Rated Cap: 76
Re: Painting a bus
We're about halfway through our conversion and have reached the painting step. Given that we are strapped for cash at the moment, we're considering using some of the many colors of house paint that we have leftover from fixing up the house. Some of it is interior, some exterior. We've started scuffing up the current paint, but I'm wondering if anyone has done this before with straight-up house paint--not Rustoleum. I'm talking Valspar and Olympic that we got at Lowe's. We had figured on doing an automotive clear coat to seal everything in, but now I'm wondering how well it will even hold to the house paint. Any suggestions?
PAtoNM is offline   Reply With Quote
Old 07-10-2008, 05:04 PM   #19
sportyrick's Avatar
Chassis: F33695
Engine: 427 chevy
Re: Painting a bus
DON'T USE HOUSE PAINT, you won't like the work involved in removing it after half of it curls up. Use rustoleum or some other kind of impliment paint, an oil base outside paint, not house paint. Like I have said in the past, you can get a modified enamel that comes in many colors for $40 a gallon, ask your local auto paint supply house. You could drive around and check the places that paint on a large scale like RR, big rigs, Maaco, body shops, etc and the may have some paint that they would part with real cheap.Or scare up the money somehow but don't ruin all your hard work with house paint. sportyrick
Old 08-08-2008, 12:52 AM   #20
DizzyIzzy's Avatar
Chassis: Chevorlet AT545 Allison auto
Engine: 8.2 litter Detriot Deisel
Send a message via AIM to DizzyIzzy Send a message via MSN to DizzyIzzy Send a message via Yahoo to DizzyIzzy
Re: Painting a bus
I agree with rick house paint and buses don't mix.
"Escapin' through the lily fields
I came across an empty space
It trembled and exploded
Left a bus stop in its place
The bus came by and I got on
That's when it all began
There was cowboy Neal
At the wheel
Of a bus to never-ever land"
DizzyIzzy is offline   Reply With Quote
Painting...here we go! opus Conversion General Discussions 3 05-13-2011 09:35 AM
Painting bus putterspitt Conversion General Discussions 12 10-05-2010 08:54 PM
I need painting help Frank ZX Conversion Tutorials and How-to's 1 08-15-2009 07:34 AM
Painting your Bus kirkndopp Conversion General Discussions 3 06-20-2009 09:26 AM
how do you go about painting joshritchie Conversion General Discussions 5 05-31-2009 05:06 PM
