Old 05-23-2016, 01:31 AM   #1
painting interior shell
Ok so a crazy idea came to me the other night. I painted the roof recently with an elastomeric paint which drastically changed the exterior roof temp even during the hottest part of the day. Now, i was wondering, in an attempt to cut down heat transfer, what is the chance the painting the interior ribs and metal with something would help as well especially since the steel ribs are the biggest culprit when it come to exterior/interior heat transferring?
does anything im saying make a wisp of sense or am i just a mad man? seems to make sence to me but idk
carneiro1292 is offline   Reply With Quote
Old 05-23-2016, 04:12 AM   #2
Chassis: Genesis
"Paint" it with spray foam.
Timelord is offline   Reply With Quote
Old 05-23-2016, 05:31 AM   #3
Arvik's Avatar
Year: 97
Chassis: BadMuthaFuka
Rated Cap: All of us
do you have link to the paint you used?
far as the spray foam, i would use a direct to metal primer and paint all surfaces you plan on spray foaming first. other wise you will rust your roof out quik as anything.
my opinion is use the elasto paint, what could really go wrong other than getting it on stuff inside? just mask your gear well.
The road is crazy.
Be safe
Arvik is offline   Reply With Quote
