Old 03-04-2007, 07:33 PM   #11
lapeer20m's Avatar
Originally Posted by rail_hauler
Anyhow here are couple pictures of my results here in Michigan.
where at in mi? i live near flint, and phill lives near grand rapids.
Old 03-05-2007, 05:46 AM   #12
rail_hauler's Avatar
I'm in Davison just southeast of Flint. Were damn near neighbors. This bus is turning out to be a fun project. We camped out in it Saturday night to test my new beds (it was 25 degrees out). We grabbed some snacks popped in a movie and everyone fell asleep before the movie was over. The beds worked great, I'm now onto the construction of a small cabinet to hold a cooler and storage bins.
I understand your heading to Buningman?
I did a little research and that seems to be a very intriguing concept.
84 Bluebird "All American FE" 40 foot
3208 Cat
4 Speed MT643 Allison
Air Brakes
rail_hauler is offline   Reply With Quote
Old 03-05-2007, 01:01 PM   #13
lapeer20m's Avatar
we are neighbors! I live in Hadley. I bowl every monday nite in davison.
Old 03-05-2007, 04:34 PM   #14
It gets even closer I'm off Hill and M-15
3208 Cat
Air Brakes
Old 03-05-2007, 10:59 PM   #15
captainkf's Avatar
Year: 1985
Engine: 366 propane
Rated Cap: 56
Originally Posted by Roasting8
Originally Posted by captainkf
I painted mine with tremclad (enamel rust paint) then coverd them with walls last year, and so far so good.
-Richard
Hi Richard, did you do anything special to prepare the windows?
I was previously looking at your conversion notes and the only thing I think you mentioned was that you painted the windows (I may be wrong, looked at a lot of web sites before asking the question).
Thanks,
Robert
Robert, first off, sorry it took so long to respond. I guess I overlooked the thread. Second, i scrubbed with dish soap, dried and sprayed. Nothing special. So far, it is still holding up great. I see that I am too late as you have already done them. Good luck, I'm sure they'll be great.
-Richard
captainkf is offline   Reply With Quote
Old 03-07-2007, 03:29 PM   #16
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Send a message via MSN to Roasting8 Send a message via Yahoo to Roasting8
-Richard
Thanks,
Robert
-Richard
Now, it's my turn to apologize for responding late.
Thanks for the info and compliment, I think the windows are going to hold up well.
Roasting8 is offline   Reply With Quote
Old 11-14-2007, 11:43 AM   #17
DizzyIzzy's Avatar
Chassis: Chevorlet AT545 Allison auto
Engine: 8.2 litter Detriot Deisel
Send a message via AIM to DizzyIzzy Send a message via MSN to DizzyIzzy Send a message via Yahoo to DizzyIzzy
Re: Painting Windows
I have a 5% tint on my windows. I was thinking instead of painting the windows. I am going to put aluminum foil on the inside then wall over the ones I wont use. The aluminum foil will add some insulation. I have tried to paint windows before, they always peel.
"Escapin' through the lily fields
I came across an empty space
It trembled and exploded
Left a bus stop in its place
The bus came by and I got on
That's when it all began
There was cowboy Neal
At the wheel
Of a bus to never-ever land"
DizzyIzzy is offline   Reply With Quote
Old 11-18-2007, 09:08 AM   #18
Roasting8's Avatar
Year: 1981
Chassis: Crown
Engine: 671 DD
Man, if I had to do it over, I would do mine with the tint and aluminum foil also. I can't complain though, the paint on the window has been holding up quite well.
Trick is to protect it from getting scraped. If it does get scraped, it's just a matter of cleaning the area and repainting.
Thanks for the idea though, I'll try it next time I have to block out a window.
Robert
Old 11-21-2007, 09:08 PM   #19
since I am going to, eventually, cover the windows inside and out, I was thinking about using some of that foil backed bubble wrap insulation to cover the windows instead of painting them. Since windows lose a lot of heat, I thought that might be a good idea.
Just some thoughts
lindy is offline   Reply With Quote
Old 11-21-2007, 09:45 PM   #20
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
I have some of that 1/4" foil bubble wrap insulation up on the front 6 windows on each side. It does a pretty fair job considering it's not fastened to the windows. I have noticed on cold days a small (3"-4") patch of condensation on 1 or 2 windows, but attribute that to not having the foil smack up against the window. On the windows I plan on blocking, I plan to paint them black and insulate (properly) with the bubble wrap.
Griff is offline   Reply With Quote
Painting a bus Chfsfn2 Conversion Tutorials and How-to's 61 06-20-2018 12:08 PM
Screening original windows and installing RV windows skoolz out Conversion Tutorials and How-to's 3 10-27-2010 01:54 PM
Painting bus putterspitt Conversion General Discussions 12 10-05-2010 08:54 PM
Painting your Bus kirkndopp Conversion General Discussions 3 06-20-2009 09:26 AM
how do you go about painting joshritchie Conversion General Discussions 5 05-31-2009 05:06 PM
