Old 02-01-2011, 06:37 PM   #1
zim
zim's Avatar
Year: 82
Chassis: TransitLiner
Engine: Cummins 5.9l
Re: Pre-Hung Exterior Door
Take a look at http://www.skoolie.net/forum/viewtop...it=door#p59755. I used 2x4's to shim out the opening to hold a smaller door. You might do something with smaller wood like 1x3's or 1x4's. As for being level, a big square can do the trick if you're just trying to make sure the frame doesn't pinch the door.
Project Blog @ TechnoVardo.com
zim is offline   Reply With Quote
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Insulate the Exterior? TygerCub Conversion General Discussions 70 03-22-2015 10:12 AM
Exterior PA? Skip Conversion General Discussions 7 12-29-2013 07:24 AM
New door... would 32" exterior steel or fiberglass work? TygerCub Conversion General Discussions 14 01-29-2011 12:26 PM
EXTERIOR LP FOR GRILL? BUSBOZO Conversion General Discussions 6 10-03-2010 06:51 PM
