Old 01-05-2016, 10:08 AM   #11
Found my little Manchester on Epay.
Old 01-05-2016, 10:22 AM   #12
NaturalStateNomad's Avatar
Chassis: Thomas
Engine: 3126b CAT
I was thinking about a Manchester and those are one of the few I found online. What are the pros/cons of going with a ASME permanent tank vs a few 20lb tanks? It almost seems like the 20lb tanks would be a lot easier to deal with as far as refilling for a person who is full timing in their rig.
The adventures of two full-time travelers from the Natural State, living in a bus and exploring life, one road at a time.
Follow along at: www.naturalstatenomads.com
NaturalStateNomad is offline   Reply With Quote
Old 01-05-2016, 11:08 AM   #13
Rated Cap: Your mom +1
I've bounced back and forth about fixed or removable propane tanks. I think since we plan on boondocking most of the time removable 20lb tanks makes more sense for us. I plan on building a storage bay under the bus with expanded metal as the floor. I figure taking a few 20lb cylinders in to town to fill them up is way easier than driving the bus into town every week or couple of weeks...
Old 01-05-2016, 11:27 AM   #14
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Some states have limits to the number of portable tanks you're allowed to carry. A good rule of thumb would be to have at least three portables (IIRC, that's the Texas limit on portable tanks for an RV) and an ASME certified permanent tank.
Captain Obvious on deviantArt
Old 01-05-2016, 11:58 AM   #15
There are pros & cons for either. Permanently mounted, DOT approved tanks are the safest and welcomed almost anywhere. But...you do have to take your vehicle to a refill station.
Portable tanks are much lighter weight and absolutely must be secured somewhere outside the bus's shell. A leaking tank inside will be disastrous and if not anchored down quickly becomes a small nuclear missile in a collision. Many hang them on the back bumper. A bad idea for what I hope are obvious reasons and can also get you banned from many parks and campgrounds and are illegal in most states to carry through any tunnel. But, when properly secured & stored, they are easy to replace or swap out at lots of locations via a toad or some other means of transport besides the bus.
I plan on using a small Manchester plus one 20 pounder as backup. But...it will be anchored in a very secure location.
Old 01-05-2016, 12:11 PM   #16
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Not that it sounds like to big of issue but permanently mounted DOT certified tanks don't need to be inspected, portables do.
