09-06-2017, 06:52 PM
Member
Chassis: TC 2000
Engine: 5.9 L Cummins Turbo
Rated Cap: 28
raised floor
In reading how most people here do their floor I am second guessing my decision to make a 1 x 2 grid on the floor, put fiberglass insulation (less toxic and flammable) between the grids then nail the plywood into the framework. Presume I will have to attach my base floor grid to the metal, but want to avoid making holes in the floor after I plug all the ones that were left behind by seats, etc. so will keep that to a minimum. My current floor is showing lots of wet wood, and thought by gluing the plywood to the metal as they did, that it held in the moisture and I want there to be an air space instead. No obvious areas of leaks besides near the wheel wells.
Anyone else do their floor this way? Also seems to be lots of rust where bolts and screws went through metal floor - is there a way to mitigate that for any new bolts/screws I add, like using stainless?
Thanks.
09-06-2017, 07:25 PM
Year: 92
Engine: DTA360 5.9L
thats how i did my floor, after raising the roof though. link to the build is in my signature there. try for January 2017 in my build and it should be around there. also did it without putting holes in my floor because i welded them all shut.
09-06-2017, 08:00 PM
Engine: DT530
I would avoid fiberglass insulation because it holds water like a sponge.
Sent from my SAMSUNG-SM-G930A using Tapatalk
09-06-2017, 08:02 PM
Very true.
I'd rather have empty space with nothing but air as insulation than have fiberglass.
09-06-2017, 08:07 PM
Chassis: Ford B600
Rated Cap: 20 person
There was another type of insulation i read in another post it was similar to rock wool. It was not supposed to hold water and was fireproof. I can't seem to find the thread now though.
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
09-06-2017, 08:19 PM
Roxul.
09-06-2017, 08:25 PM
Member
Chassis: TC 2000
Rated Cap: 28
Didn't realize that. Foam board burns and spray foam is toxic so will have to find something else.
09-06-2017, 08:38 PM
Chassis: Ford B600
Should have known CB would know!
The Bowser Journal
09-06-2017, 10:02 PM
Buses burn, even without foam.
How is it toxic?
09-06-2017, 10:25 PM
Coachwork: Carpenter Body
Rated Cap: 65 to Zero. Folding Chair
I skipped the framing period.
One inch foil faced under two inches of rigid with plywood directly over top.
A floating insulation floor.
PL sub flooring foam safe glue did a better job than screws, framing or folding and crushing it down.
I will never build thermal bridges in a floor again.
D.L. Jones III
"The Independence"
98 International
09-06-2017, 10:29 PM
Engine: DT530
Agreed!
Rigid foam has a 15-25 psi rating so there is no need to frame.
09-07-2017, 10:25 AM
I am a big guy, 6'4 300lbs and I have not had an issue with the insulation beneath me.
It has not peeled, curled, lifted, or anything from the metal floor. I put 2x2s on the floor under the seat rail to provide an anchor point for surface walling and it also gave me a great space to mount plywood to the steel and run my electrical and plumbing without interfering with the insulation value.
An unexpected little bonus and a lot of saved framing material that can be used elsewhere.
D.L. Jones III
"The Independence"
98 International
09-07-2017, 01:10 PM
Member
Chassis: TC 2000
Rated Cap: 28
Thank you, will check this out.
09-07-2017, 01:52 PM
Chassis: Ford B600
I didn't know that about rigid foam! I am a big guy as well, 6 ft 1 280 so it was a concern.
The Bowser Journal
