Old 11-16-2013, 06:08 PM   #1
wmkbailey's Avatar
Engine: 3126
Re: Remove rubber flooring.
I used a 70 in. Tamper Head Digging Bar that weighs about 20 lbs and beat myself and the bus to death until the rubber gave up and came off. Why make it easy?
William
http://thejourneyvisvi.com/
My Conversion Thread:
viewtopic.php?f=9&t=464989
Old 11-25-2014, 09:23 PM   #2
Coachwork: IC
Chassis: CE300
Rated Cap: 32
mine simply peeled up without much of a fight. It came out in whole pieces and was very thick. My bus didn't come with plywood floors, just metal with rubber on it.
Roll Your Own Build Thread
Old 11-25-2014, 10:17 PM   #3
lornaschinske's Avatar
Rated Cap: 89
Metal with very well stuck rubber. Floored over the rubber. Figured the rubber would help with the sound deadening. Maybe.
Fulltime since 2006
Old 11-26-2014, 07:10 AM   #4
Coachwork: IC
Chassis: CE300
Rated Cap: 32
But it smells so much better once that puke mat is out!
Old 11-26-2014, 09:47 AM   #5
Chassis: B3800 Short bus
I removed the plywood subfloor with a long pry bar, circular saw and ratchet straps. It was a messy operation.
first, I set the circular saw to the thickness of the rubber + plywood, then made a couple lengthwise cuts. From there I used the pry bar to wedge under the floor and pull it up a bit. Next, since I had some of the windows out, I wrapped the ratchet straps around some of the ribs and put the hooks on the lifted edge of the plywood. Then I walked along the ratchet straps and slowly tightened each one. This worked for most of the plywood pieces, except for some that were wet and nasty. They broke and I had to pry them up with the bar. Most of the nails that were holding the plywood down actually pulled through the plywood, not out of the metal. I had to go over the floor with the pry-bar and pull out the nails one-by-one.
Old 11-26-2014, 01:13 PM   #6
Rated Cap: 89
Ours did not and does not smell. Not even in temps above 100F.
Fulltime since 2006
Old 11-27-2014, 04:10 AM   #7
Coachwork: ward
Chassis: international
Engine: dt360a
ditto. i soaked ours in purple power cleaner, then pressure washed and allowed to dry. then insulated,covered in osb, linoleum. smells like a new house ............so far! lol
Old 11-27-2014, 07:01 AM   #8
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Dog owners say the same thing...
But seriously unless your bus is brand new, I'd want to see what the condition of the floor is before I built a house on it. It's like the "foundation". As the member above said- Its messy, wet and rotten oftentimes. I have a few little rust spots that I'd hate to cover up without addressing.
Old 11-27-2014, 10:53 AM   #9
Rated Cap: 89
Sorry. Post has been removed. My husband died a couple weeks ago. I think I should rerain from posting until things get better. Bye
Fulltime since 2006
Old 11-27-2014, 01:23 PM   #10
I am a cat person....so ugh...dogs smell better
I have no issues with any smell.....except when I sweat
Which is about every time I drive her....I got some fuel additive so I need to drive her this weekend so I can fuel up and then do tub
Remove or Not to Remove - Rubber Floor... usmcbay Conversion General Discussions 29 01-14-2017 05:44 PM
Flooring & Sub Flooring Question QUIKSVT Conversion General Discussions 1 07-14-2012 09:11 AM
Remove rubber floor?? and wall panel body strengthening?? adamanderr Conversion General Discussions 10 01-06-2008 12:49 AM
Removing rubber flooring KC10Chief Conversion General Discussions 9 12-08-2007 07:22 AM
Removing the Rubber Flooring--Good idea? Skoolie BOBB Conversion General Discussions 17 07-28-2005 10:08 PM
