Remove walls without damaging them?
We are converting a 2002 GMC Thomas shorty. We were fairly happy when we saw there were no rivets, only screws, holding the walls on. I decided to remove some wall panels to make it easier to run some wiring where I want it, but I'm currently stuck...
I removed all the screws from the wall panel and started to pull it away from the wall. All went well until I got up by the window. It looks as if the aluminum might be folded over under the windows? Is that the case?
Is there an easy way I can remove the wall panel without damaging it so I can put it back in? Every tutorial I find is from people drilling out rivets and gutting the bus with no intention of reusing any of the wall materials...
Thanks!
