Old 04-10-2008, 09:26 AM   #1
Engine: 5.9l Diesel Cummins
Rated Cap: 20
Removing the back door.
I'm leaning towards removing my back door and covering it with sheet metal and insulation. Has anyone done this before? The added space in the back would be used for a bench with my fresh water tank going under it as well as my water pump, expansion tank and water heater.
Thanks!
My 1997 Ford / Thomas shorty
5.9l Diesel Cummins w/automatic tranny
Photo's of my bus build
Billsman is offline   Reply With Quote
Old 04-10-2008, 11:47 AM   #2
swinada's Avatar
Re: Removing the back door.
why remove it? in my eyes that would be unnecessary work. I would just leave it, you can still build a bench there and put your tank under. This way you could set up your plumbing and pump to be accessed from the outside. And you never know, maybe one day you wanna move something a little bigger in or out of the bus and then its nice if you can just open the big door.
Proud owner of a: 1996 Thomas Safe-T-Liner,Cummins 6CTA 8.3Lt diesel, Allison AT.
https://picasaweb.google.com/swinada/BusPictures https://www.swinada.com/bus.htm
https://lh4.ggpht.com/swinada/SL91F-b...opbussmall.jpg
swinada is offline   Reply With Quote
Old 04-10-2008, 07:08 PM   #3
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
this was done to my bus when i got it the door is still there but it is glassed closed and the hinges are gone the fresh water tank is in the bus and this is the sleeping area i like it but it would be better if the door still opened
Old 04-11-2008, 12:37 AM   #4
Rated Cap: 20
I never used the back door on my other bus that much plus I have cancer on the bottom and the hinges are pinched which make a terrible noise when opening or closing. So even if I did keep it I would have to pull it off and do a bit of work to it.
Thanks for the feed back.
Old 04-11-2008, 01:10 AM   #5
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
i would like to have an emergency exit at least on my bus since the door is no more at the back window that would be good...gonna be sanding there this weekend will post some shots of what it looks like after the 145667 coats of paint are gone timbuk
Old 04-20-2008, 01:14 AM   #6
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
there she is the door is still in there i can see the drip rail its a 20 by 30 window id like that to become emerg exit access soon be stripping and priming but it snowed today
Old 04-28-2008, 02:51 AM   #7
odyssess's Avatar
Engine: T444E 3800
As peaceful as Canadians are, you would think they would be better at drawing a peace sign....Unless of course it's a Mercedes schoolbus. Just kidding Timbuk
https://www.skoolie.net/gallery/v/Skooli ... Green+Bus/
Keep on Keeping on.
odyssess is offline   Reply With Quote
Old 04-28-2008, 06:57 PM   #8
timbuk's Avatar
Year: 1965
Coachwork: thomas
Chassis: chevy
Engine: 350
yep blew that one totally......missing a line........nothing left of it know![
Replacing Bus Door with Wooden Exterior Door lornaschinske Conversion Tutorials and How-to's 25 09-28-2017 02:54 PM
Emergency Back door wiring brasskeynj Titles, Insurance, Registration and Money Matters 2 09-17-2014 02:10 PM
Removing Air Door Mechanism Hex Conversion General Discussions 0 06-14-2011 09:08 AM
Electric back door lock...who posted the pics? Abbott Conversion General Discussions 4 08-11-2008 09:50 PM
Removing door to get to those stairs pangaia Conversion General Discussions 2 05-26-2007 01:22 AM
