Old 07-25-2010, 12:05 PM   #1
lornaschinske's Avatar
Rated Cap: 89
Re: Removing Vinyl Numbers/Letters
I just peeled them off on a hot day. Left glue on still. You can still see where it said "WildWater LTD Rafting" the website and the 800 number. It also peeled some of the paint off to so you can see "school bus paint" under it. I also utilized the "razorblade" method on some parts as well. I dropped a razorblade behind a rub rail... took months before I could get the thing out (in pieces).
Fulltime since 2006
Old 07-25-2010, 12:32 PM   #2
Stuff's Avatar
lol my bus i can see a few places owned it. richie brothers auctions, something in victoria, and looney toons shows
Old 07-25-2010, 06:27 PM   #3
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Engine: 6.6L Turbo Diesel
Rated Cap: 26
Mine came off easily after sitting in the sun and using my fingernail and patience....
M1031 is offline   Reply With Quote
Old 07-25-2010, 08:22 PM   #4
Rated Cap: 89
Originally Posted by M1031
... patience....
What's that?
Fulltime since 2006
Old 07-26-2010, 07:46 AM   #5
Seeria's Avatar
*takes notes since she should have a bus this month dang it*
Would a hair dryer work? At this rate it might be too cold for the sun to heat up letters to peel off
Old 07-26-2010, 08:24 AM   #6
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
... patience....
What's that?
Well for a paramedic, it's when someone calls 911.........
Old 07-26-2010, 11:35 AM   #7
Rated Cap: 89
So that the doctor can practice on them? How long does a doctor have to practice medicine before they get it right?
Fulltime since 2006
Old 07-26-2010, 02:40 PM   #8
Stuff's Avatar
oh there is a fine line for temp. too much and it just stretches and tears, not enough and it breaks off.
Old 07-26-2010, 08:05 PM   #9
M1031's Avatar
Coachwork: Ward
Chassis: Ford B600
Rated Cap: 26
When all else fails.....kill it with fire!
NAPALM!!!!!!!!
Old 02-12-2017, 11:14 AM   #10
JojoBrisk's Avatar
Chassis: TC 2000
Engine: 5.9L Cummins
Originally Posted by M1031 View Post
NAPALM!!!!!!!!
All I have to say to this is Hooah!!!
JojoBrisk is offline   Reply With Quote
Old 02-12-2017, 03:03 PM   #11
roach711's Avatar
Rated Cap: 19
Napalm will definitely do the job. You can also call C4 Solutions at 1-800-BIG-BOOM.
I used a hairdryer to soften my lettering and a plastic razor blade to help peel it off. The adhesive didn't come away quite so easily. I tried several solvents (acetone, paint thinner and diesel fuel) but in the end plain old gasoline worked best for me. I'd slather some on a section, wait a few minutes then scrape it off with my plastic razor blade thingy.
The Roach Motel
Old 02-12-2017, 04:50 PM   #12
I got myself a heat gun from Harbor Freight. $9. It softened the letters up enough to pull them off but left the glue. Ill try gas to remove the glue. It actually looks cool, like ghost letters.
Without heat the letters were brittle & would just break off into pieces.
BigDavid is offline   Reply With Quote
Old 02-12-2017, 05:20 PM   #13
3m adhesive remover or even some brake cleaner will get the glue off.
Old 02-12-2017, 07:05 PM   #14
Thanks for the tip.
Old 02-12-2017, 07:47 PM   #15
Scooternj's Avatar
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
I used Goo Gone and worked very nicely.
Captain Obvious on deviantArt
Old 09-30-2017, 03:56 PM   #16
golfersmurf57's Avatar
Even after glue is gone unless you're going to paint, get some rubbing compound for the shadows and lots of elbow grease
Sent from my LGL64VL using Tapatalk
golfersmurf57 is offline   Reply With Quote
Old 10-03-2017, 05:47 AM   #17
Coachwork: Chevy
Chassis: C60
Engine: 8.2 diesel "Fuel Pincher"
Rated Cap: GVWR 27000
Post Used to do this for a living...
The best for removing old vinyl is a dryer. When you get that off, there is a product called: Rapid Remover (used to have a different name) Goo Gone will work too. Rapid remover works fast and is water based.
Anyway, it turns the adhesive into a gel. Get a plastic vinyl application squeegee. Scrape off the gel and wash the surface.
Getting ready to do my own skoolie in the next month or so..
meyermobile is offline   Reply With Quote
Old 10-03-2017, 09:16 AM   #18
Traveling
Rated Cap: '00
Like he says ^^^
It is a finesse thing- don't over or under heat, pull the lettering slowly at a sharpish angle. If you do it right, the adhesive stays on the vinyl. Helps to have 2 people- one holding heat source. plastic razor is nice.
This is a great job to pawn-off on teens.
Removing School Bus Letters waste-not wagon Conversion Tutorials and How-to's 16 05-03-2015 11:49 PM
looking for vinyl or stencils bansil Everything Else | General Skoolie Discussions 1 01-10-2013 04:29 PM
anybody here cut vinyl for graphics?? bansil Everything Else | General Skoolie Discussions 16 12-18-2012 06:24 PM
Blue Bird letters opus Skoolie Conversion Projects 11 07-21-2011 10:12 PM
Vinyl Wraps... cjgbur Conversion General Discussions 0 09-13-2010 03:23 PM
