Old 01-18-2018, 06:23 PM   #1
BowserJournal's Avatar
Chassis: Ford B600
Rated Cap: 20 person
Replace Emergency Exit with skylight
So my wife, who is in charge of the skoolie layout, just told me that one of the emergency exits will be a skylight. I am good with that because I don't have to patch it over now.
Here's the rub, I have no idea how to do this. Does anyone know or have seen anything like this being done?
"Living Our Own Story"
The Bowser Journal
Watch our adventures by subscribing...
Youtube - bit.ly/TheBowserJournal
BowserJournal is offline   Reply With Quote
Old 01-18-2018, 07:01 PM   #2
Go to Sojourner's thread and start at post 571.
Old 01-18-2018, 07:27 PM   #3
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
Perfect time to ask, because he just completed 4 great looking ones!
jjhwick119 is offline   Reply With Quote
Old 01-18-2018, 08:12 PM   #4
CaptSquid's Avatar
Chassis: HDX
Engine: Cat C7
Rated Cap: 84 passenger
Not to argue with SWMBO, but a skylight also lets in heat during the summer months. At least the E-hatches are somewhat translucent rather than transparent.
Old 01-18-2018, 09:26 PM   #5
Chassis: Ford B600
And in the winter when you need it! I can always put up a curtain to knock down the sun in the summer!
The Bowser Journal
Old 01-18-2018, 09:29 PM   #6
I like RV roof vents. VERY functional and they draw very little current so they're great for cooling down without a lot of battery drain.
Roll Your Own Build Thread
Old 01-18-2018, 09:33 PM   #7
Robin97396's Avatar
Perhaps they use curtains over the skylights during the summer. I'd put insulation panels in the skylights for thermal purposes, which of course cancels the original purpose of the skylights.
I've found I don't like the strong sunbeams coming in through the ceiling during the summer, and I'm only using the hatch. The sunbeams are like a spotlight aimed in through the ceiling making it difficult to see anything that isn't hit by the beam of light.
Robin
Nobody's Business
Old 01-18-2018, 10:12 PM   #8
I'm okay with the rigid foam plugs for the skylights, that way you can have the light come when you want and closed when you're trying got cool. My only experience living in a tin can happened in 1975 when I first moved back to southern Calif and stayed with my brother. he had no bed space in his crammed house so I had to sleep in his converted van. Let me tell you, once that sun came up you didn't need an alarm clock, you started baking before 8 am.
Old 01-18-2018, 10:56 PM   #9
Robin97396's Avatar
If you strip down the interior of a bus, you'll definitely feel the heat if you're in the sun. I'm in a colder climate and this bus was unbearably hot with just the outer skin for sun protection in the early summer before it got insulated. Having my head near the ceiling was like standing under a broiler.
Robin
Nobody's Business
Old 01-19-2018, 04:25 PM   #10
jjhwick119's Avatar
Engine: Dt466e
Rated Cap: 71
I hadn't even considered that. That's gonna make me rethink the idea.
emergency exit
