04-02-2013, 12:50 PM
#21
Rated Cap: 89
Re: Replacing Bus Door with Wooden Exterior Door
We have the magnetic "As Seen On TV" screen door. I bought it at Family Dollar last summer. Works pretty good. Especially when your hands are full of grilling stuff. I put it up last summer using the velcro. This summer, David will finish the entry door and trim moulding. I will use snaps to install the screen. Right now only the top edge is snapped in place with one snap at the bottom on each side. I want to replace the door handle with a lever type and a bolt on the interior (for security).
09-28-2017, 02:21 AM
#22
Door conversion
Hello I'm new here, I have a few questions on taking out the folding door and putting some type of solid door in place. My bus is on blocks and dont run so I'm not worried about seeing through the door.
First when you change the doors what do you use to seal the door at the bottom step?
I'm guessing I would have to build a frame for the door , I like the idea of using 1 tubing and skinning the tubing with sheet metal or would it be cheaper and easier to just buy a solid core blank door for home depot .
would it be better to recess the door or just make it flush with the old opening.
the bus is a 1977 Thomas , it was stripped out and made a hunting camp when i bought it, the main problems I am having is mice getting in from someplace and the doors not sealing when closed, which is where I think the mice are getting in from. Also those doors allow the cold right in .
09-28-2017, 10:23 AM
#23
Rated Cap: 19
I'd get a pre-hung door from the local Homely Depot and frame it in like you would a house door. The pre-hung door will be weather sealed and ready to go.
09-28-2017, 01:07 PM
#24
how about an rv door?
09-28-2017, 02:26 PM
#25
I have seen a few "house" doors on RV's that worked OK, but most leaked air & water. Some pretty badly. For some reason the designers didn't take into consideration the houses going 70mph for hours on end.
PS...My '46 Chevy came with "hippie built" wooden door that was trashed long before I got it. It went bye-bye. I built my own steel framed entry door.
09-28-2017, 02:54 PM
#26
Leave the door as is and install a cat.
