Old 07-28-2015, 05:33 PM   #11
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Originally Posted by Timelord View Post
Be aware that UTXexchange is currently hacked and malicious as indicated by Google search and Avast Antivirus.
here is the info from the page-
Automatic Models MTB 643 up to 210 nhp (157 kW)
Transit Bus/Shuttle Bus
Net input power (max).............................210 hp (157 kW)
Input speed range................................2000 - 4000 rpm
Net input torque (max)........................590 lb ft (800 N�m)
Vehicle weight.......................Up to 37,480 lbs (17,001 kg)
Mounting
Direct..............SAE 2 flywheel housing with flex plate drive
Torque converter
Type..........................Single-stage, 3-element multiphase
Stall torque ratio.........TC 350-3.04; TC 360-2.86; TC 370-2.40;
TC 378-2.27; TC 380-1.82
Lockup Clutch, automatic..................Effective in 3rd & 4th
Gearing
Type..........................Constant mesh, spur type planetary
Range Ratios*:
First...................................3.58:1
Second..................................2.09:1
Third...................................1.39:1
Fourth..................................1.00:1
Reverse.................................5.67:1
* Gear ratio does not include torque converter ratio.
Power takeoff provision
Converter driven (SAE 6-bolt)
Location............................Right side (viewed from rear)
Drive gear ratio................All ranges--1.00 x turbine speed
Drive gear rating.............................300 lb ft (407 N�m)
Oil system
Oil type.........................................Dexro n II�, C 4
Capacity (excluding external circuits)....18 U.S. qts (17 liters)
(with std. oil pan)
Filter............Full flow, replaceable element, remote mounted
Cooler............................................ Remote mounted
(Filter and cooler not furnished on transmission assembly but are supplied
by vehicle manufacturer.)
Size
Length..........................................30 .4 in (773 mm)
Width...........................................19 .3 in (489 mm)
Height..........................(with 5.1" pan) 22.4 in (568 mm)
Weight (dry)....................................510 lbs (231 kg)
Old 07-28-2015, 07:45 PM   #12
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Lol try this one instead-
http://www.5z8.info/stealgmailpasswo...3yh_worm]Voith Turbo Web Services
Old 07-28-2015, 09:02 PM   #13
Chassis: Genesis
Uh... Did you mean to post that link?
Timelord is offline   Reply With Quote
Old 07-28-2015, 09:04 PM   #14
Chassis: Genesis
Oh you smartass. :P
ShadyURL - Don't just shorten your URL, make it suspicious and frightening.
Old 07-28-2015, 09:05 PM   #15
opus's Avatar
Chassis: All-American R/E
Originally Posted by rvingoffgrid View Post
they don't make retarders for the older non electronic trans.
[waves] I have a retarder on a non-electronic 643.
Old 07-28-2015, 10:01 PM   #16
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Sorry, boredom in the FL rains got the better of me!
