07-28-2015, 01:12 PM
Chassis: Wanderlodge FC32
Engine: Cat 3208 NA
Rated Cap: n/a
Retrofitting a retarder
I have a 1998 BB TCFE400 with a Cummins B235 and an Allison MT643.
When we're on holiday in mountainous areas (France, Germany, Austria, even Belgium or Luxemburg) I often feel the miss of an engine brake or retarder.
Voith told me they can't fit a retarder on my drive shaft "because it is American" (everything is metric, so I think this is BS!)
Has anyone ever converted an Allison MT643 to a MTB643 or 644? What are your experiences?
Regards,
Ernst & Sylvia
07-28-2015, 01:31 PM
Very cool location!
I too am interested in this subject... I know there is a place in Colorado that specializes in driveline retarders and fitting them.
07-28-2015, 01:33 PM
Coachwork: happy camper RV repair
Chassis: international
Engine: 360 international
Rated Cap: 66 passenger
they don't make retarders for the older non electronic trans. they do however make a electric retarder that goes on the differential. called a thelma. i believe its made across the pond as they say, germany maybe? not sure of its origin. some of the buses i have converted had them on them the dina mexican made buses had them they worked well but where prone to problems like all german electronics, they are pretty good with mechanical things but electronics are best left to americans or japanese. but i would think you could get one pretty cheep if you can find a source might start looking for a bus junk yard like nimco, and see what they charge for a used one off a old dina. i found this on the web http://www.telmausa.com
rvingoffgrid.com
07-28-2015, 01:51 PM
Engine: Cat 3208 NA
Rated Cap: n/a
Thanks! I'll look into Telma again. Last time I searched, they only had 24 V versions. As you say, quite affordable on different truck scrap yards. There hardly are any trucks in Europe with a 12 V installation
Regards,
Ernst & Sylvia
07-28-2015, 03:40 PM
I could have sworn Allison built an "R" version of the 643... and that the R stood for "retarder".
07-28-2015, 03:43 PM
The MTB643 has the output retarder.
07-28-2015, 04:00 PM
Engine: Cat 3208 NA
Rated Cap: n/a
So how can I change a MT643 into a R or B version....?
Regards,
Ernst & Sylvia
07-28-2015, 04:19 PM
07-28-2015, 05:26 PM
Chassis: Genesis
Be aware that UTXexchange is currently hacked and malicious as indicated by Google search and Avast Antivirus.
07-28-2015, 05:28 PM
Engine: Cat 3208 NA
Rated Cap: n/a
My Avast told me so....
Thank you for the links. I'll look into it tomorrow.
Regards,
Ernst & Sylvia
07-28-2015, 05:33 PM
here is the info from the page-
Automatic Models MTB 643 up to 210 nhp (157 kW)
Transit Bus/Shuttle Bus
Net input power (max).............................210 hp (157 kW)
Input speed range................................2000 - 4000 rpm
Net input torque (max)........................590 lb ft (800 N�m)
Vehicle weight.......................Up to 37,480 lbs (17,001 kg)
Mounting
Direct..............SAE 2 flywheel housing with flex plate drive
Torque converter
Type..........................Single-stage, 3-element multiphase
Stall torque ratio.........TC 350-3.04; TC 360-2.86; TC 370-2.40;
TC 378-2.27; TC 380-1.82
Lockup Clutch, automatic..................Effective in 3rd & 4th
Gearing
Type..........................Constant mesh, spur type planetary
Range Ratios*:
First...................................3.58:1
Second..................................2.09:1
Third...................................1.39:1
Fourth..................................1.00:1
Reverse.................................5.67:1
* Gear ratio does not include torque converter ratio.
Power takeoff provision
Converter driven (SAE 6-bolt)
Location............................Right side (viewed from rear)
Drive gear ratio................All ranges--1.00 x turbine speed
Drive gear rating.............................300 lb ft (407 N�m)
Oil system
Oil type.........................................Dexro n II�, C 4
Capacity (excluding external circuits)....18 U.S. qts (17 liters)
(with std. oil pan)
Filter............Full flow, replaceable element, remote mounted
Cooler............................................ Remote mounted
(Filter and cooler not furnished on transmission assembly but are supplied
by vehicle manufacturer.)
Size
Length..........................................30 .4 in (773 mm)
Width...........................................19 .3 in (489 mm)
Height..........................(with 5.1" pan) 22.4 in (568 mm)
Weight (dry)....................................510 lbs (231 kg)
07-28-2015, 07:45 PM
07-28-2015, 09:02 PM
Chassis: Genesis
Uh... Did you mean to post that link?
07-28-2015, 09:04 PM
Chassis: Genesis
07-28-2015, 09:05 PM
Chassis: All-American R/E
[waves] I have a retarder on a non-electronic 643.
07-28-2015, 10:01 PM
Sorry, boredom in the FL rains got the better of me!
01-09-2021, 08:44 AM
Engine: Cummins 8.3
I know that this is a very old thread, but does anyone need info on the Allison output retarders?
01-09-2021, 09:18 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Originally Posted by s2mikon
... does anyone need info on the Allison output retarders?
Vague...but interesting. Do you mean info on adding them, or do you happen to have retarder diagnostic/repair expertise? If the latter, then yes! We have a retarder that shows high temp in cruise and almost feels like it's not releasing immediately after a stop (meaning the fluid isn't evacuating promptly?). I'll be digging into the valve shortly, but if you have insight I'd welcome it. Thanks!
01-09-2021, 09:24 AM
Engine: Cummins 8.3
I have the Allison technicians guide inspection/analysis book and the SAE Technical Papers on the output retarder. This is for the 600/700 series transmissions. How is your unit controlled?
01-09-2021, 09:32 AM
Year: 1974
Chassis: "Atomic"
Engine: DD 8V71
Thanks - unfortunately, ours is a B400R...
