09-13-2015, 05:31 PM
Year: 91
Coachwork: BB
Rivet removal
What is the best method for removing rivets from the ceiling and wall panels?
Is there really no way to do a specific search on this forum?
09-13-2015, 05:48 PM
Chassis: MVP
Engine: CAT 3116
Drill out the center of the rivet and then use a chisel and hammer to knock of the head.
In order to search the site just do a search on google for the term and and add site:Skoolie.net
Like this:
Let me google that for you
09-13-2015, 08:46 PM
Year: 91
Coachwork: BB
Thanks Piersg.
After drilling for a couple hours, I ended up using a center punch to knock out the center of the rivets and then was able to use a chisel to remove the heads.
i'm starting to think it doesn't get cold enough around Seattle to warrant replacing those old insulation bats.
09-13-2015, 10:40 PM
Hi! So from my way of thinking for over all comfort I would want to replace and increase the insulation R-value for sure. But knowing that your in the pacific north west. I couldn't imagine not getting that old batt ins. out. The primary reason would be your long term health and even short term if you have any issues with mold. Here's a good read from one of the other threads last week.
http://www.skoolie.net/forums/f10/in...nks-11210.html
09-14-2015, 04:52 AM
Chassis: International 3000RE
Engine: T444E/AT545
Rated Cap: 75
Not taking mold into consideration, better insulation means less work your HVAC set up has to do to keep the interior comfortable. Remember, the majority of bus manufacturers use batting that's cheap and provides a minor level of insulation, since their logic is "It's only used twice a day; it's not like they're going to be living in it"
09-14-2015, 10:29 AM
Chassis: All-American R/E
We get -35 here and there was still no way I was ever going to attempt to take all those rivets out!
09-14-2015, 11:12 AM
Way back when I had good luck using a thin metal cutting disk on an angle grinder ...cut an "X" down to the surface, whack it with a good cold chisel to pop off the head, then a pin punch to knock out the body. Much faster than drilling but you just have to exercise care not to carve up the sheetmetal.
Then of course...there is a tool known as a "rivet shaver" that is made to do the job but I found them pricey & tricky to use.
09-14-2015, 12:48 PM
Engine: 190hp 5.9 Cummins
Good old 4 pound hammer, a long 16 inch by 1.5 inch wide cold chisel with hand guard, and a good arm is all that's needed.
I don't understand why people are so lazy. Fearful of a little hard work.
All the mechanical ways can be faster. However, they are much louder, require $$ investment, ect.
09-14-2015, 02:28 PM
I have all the power tools needed to do this easily and I still wouldnt do it! Not enough gain to bother with. You still have the issue of radiant cold/heat through all the steel.
Spray foam is the way to go but I wouldnt be interested in that stuff in living quarters.
09-14-2015, 04:06 PM
Exactly the way I did it.
My reason for not using a big (really big) hammer was that I didn't want to hurt or distort the steel framing the rivets were fitted into.
09-14-2015, 05:57 PM
Chassis: AARE 3903
Engine: Cummins 6CTA 8.3
Center punch the head, hurdy gurdy drill the head off, pin punch the buck.
Power tools are not allowed on military aircraft... LOL
09-15-2015, 05:22 PM
Engine: Navistar T444E Disel V8
Rated Cap: 71
Angle Grinder and a punch. Cut off the heads, tap out the shaft. I did all my exterior rivets in 30 minutes once I started with that method.
12-15-2015, 05:56 PM
Chassis: TC 2000
Engine: 5.9
Rated Cap: 83
I used an air chisel. First I used a center punch style tool to punch the center pin in then a flat chisel type tool to cut the head off. Keep the chisel sharp and it cuts the heads off easily. Same with the bucked rivets, keep the chisel as sharp as possible and it will cut through them. Too bad there are about a cajillion of them.
Hopeless Busaholic!
12-15-2015, 07:29 PM
Year: 98
Chassis: D
Engine: 7.2L turbo Cat C7 3126
I also used an air chisel. First I used the narrow punch to push the center pin back a few millimeters. Then I tried a few different chisels. I found that the one with a V in the center and a 30 degree bend in it worked best. Because the center material has been pushed inwands, the first few chisel strikes allow one end of the rivet to be smashed into the newly created void. This also creates a little lip and the bent chisel head can get behind it. It it didn't cut through right away, I was able to do a little prying motion while the chisel was running, kinda like a crowbar, and that popped the rivets right out. Luckily, my bus has a lot of screws, only every fifth one was a rivet. Still, a short step stool will help a ton to keep your arms from getting too sore.
The first pass, with the center punch, each rivet took about 4-5 seconds. One the second pass, with the bent chisel, each rivet took 3-8 seconds to remove.
01-02-2016, 06:45 PM
After trying the drill out and chisel method I fell back on just burning grinding disks, I found with a bit of practice and not caring about the sheet metal I was able to blow through rivets rather quickly and effectively.
