Originally Posted by wotb
If all I get is directed to other threads then great, but I haven't been able to find them so can you weld in body patches or only rivet and what kind of caulking should I use for the roof seems thanks, Michael
I welded patches to the back side of my flasher holes, with nearly zero experience. I used a little Hobart 135 that I bought off Craigslist. Hopefully the roof doesn’t fall off during a rainstorm. They turned out fine for me. A skilled welder would definitely scoff at my work, but after the bondo, sanding and paint...I doubt anyone can tell. I like that there won’t be any evidence of preexisting lights in each space. The flat surfaces look clean & tight! I have some photos posted on my build thread I think. If you are curious about how I did it, let me know and I’d be happy to share my amateurish procedures!
There is some truth in the fellow that mentioned the warping. I put a little too much heat to the first patch, which created an ever so slight bow to it. You can only see it from a certain angle when the sun shining on it. My wife didn’t notice so I’m in the clear[emoji2]. All the rest are straight. Also, if you chose to weld, be sure to cover your the windshield/windows below the weld work with something to protect from splatter.
