Old 10-31-2015, 06:05 PM   #1
Roof Options
I need to raise the roof of my bus, buy I don't have the money to pay a welder. What are the most cost effective options, preferably that I can do myself or with a minimal amount of people?
I've heard talk of fiberglass roofing, but I'm not sure how much that costs or if I can do it myself.
Thanks in advance
Bucky is offline   Reply With Quote
Old 10-31-2015, 06:14 PM   #2
Coachwork: IC
Chassis: CE300
Rated Cap: 32
You can raise it without welding just use bolts or rivets.
But finding someone to weld for a few hrs isnt terribly expensive.
Old 10-31-2015, 06:21 PM   #3
Engine: 190hp 5.9 Cummins
I didn't weld anything on my roof raise. I bolted everything together.
Pics and details can be found here.
http://www.skoolie.net/forums/f11/th...ime-10138.html
Old 11-01-2015, 09:17 AM   #4
Engine: Navistar T444E Disel V8
Rated Cap: 71
I did a similar method as Nat, and it couldn't have been easier! Make sure you get custom hat channels made, it's the only way to go. Be sure you use locking nuts with your bolts, and make sure you use enough, otherwise you'll regret it when you're climbing on your roof later! Also I would advise to check for roof leaks and various other roof jobs before raising it!
Intalleyvision is offline   Reply With Quote
Old 11-01-2015, 10:52 AM   #5
Intalleyvision speaks truth. Do as much as you can to the roof before raising it. Two feet taller makes a big difference.
I used regular nuts and seam seal to lock the threads to keep them from coming loose.
Construction scaffold is nice for safely working on the exterior of the bus before and after the roof raise.
Old 11-08-2015, 08:59 AM   #6
2kool4skool's Avatar
Don, Mary and Spooky the cat.
Old 11-08-2015, 09:18 AM   #7
With a bit of front slope, that would have looked great.
