Old 04-23-2019, 04:12 AM   #1
Year: NA
Roof raise guide - tools to align as it goes up?
I'm having trouble finding more details on how/where people are doing the items that hold the 4 corners of the bus while the roof is being raised. I'd love some slick ideas.
Looks like threaded rod fed through two pieces affixed to the inside of the hat channel, with some bolts to hold it in place as you extend it up.
Do people sell these prebuilt to save others more engineering time?
Thanks!
Dave aka Ghan
Ghaniba is offline   Reply With Quote
Old 04-23-2019, 05:38 AM   #2
Thanks!
Dave aka Ghan
Nothing prebuilt necessary. Buy some all-thread, some nuts, and some tubing and that's all you need. Well, a welder too.
Roll Your Own Build Thread
Old 04-23-2019, 06:18 AM   #3
Year: NA
Awesome. Curious if anyone has any estimation of the weight of the roof. How much welding do you do for those? Must be a balance - more weld is safer, less weld is less grinding. Thinking 1" top and bottom of each side of each of the 4 tubes. Thoughts?
Dave aka Ghan
Old 04-23-2019, 06:53 AM   #4
Dave aka Ghan
Very little welding needed.
The roof isn't as heavy as it looks. Its basically a large sheet of 18ga. Folks WAY overestimate how heavy it is when planning a raise.
I'm not sure what you mean by less time grinding. I didn't do any grinding, just welding.
Old 04-23-2019, 07:02 AM   #5
Year: NA
I would assume you removed the welded on raising devices? Or did you bolt yours on somehow?
Curious, what gauge does everyone user for the new sides? 18 guage as well? I think I've heard people say 20gauge?
Dave aka Ghan
Old 04-23-2019, 07:34 AM   #6
Dave aka Ghan
ah, yeah those I did cut off with an angle grinder.
That part's super easy!
Anything thinner than 18ga is a pita to work with and is overkill. The buses I've got are all right around 18ga for skins. The hat channels are right around 14ga.
20ga is pretty thin. I've used it for a couple windows a friend wanted deleted and it turned out alright.
Old 04-23-2019, 08:00 AM   #7
I've still got my raise mechanism. I'll sell them to you if you want. Shipping might be expensive. PM me about the lift mechanism. I welded them on, then cut them off. If I did it again. I would use a few bolts to attach them to the ribs.
You want to level the bus front to back and left to right. You need some heavy duty bottle Jack's and wood for "cribbing". Basically little wood pyramids to support the frame. You need to stabilize the frame so it doesn't flex when you pop the top. The weight of the engine can flex the frame. Once you frame is stabilized and level, hang a plumb line at the front and rear and mark an x on the floor. That's how you will know your roof went up perfectly straight.
Check my instagram for some pics... 5speedhouse
Rochey6957 is offline   Reply With Quote
Old 04-23-2019, 08:16 AM   #8
Year: NA
This is just to be more precise, right? If the measurements between all of the cuts is exactly matching, it can't really be off, can it? Or is there something I'm missing? I think it'd be a good idea to level off the frame. Wonder if my big Jack stands will reach that high...
Old 04-23-2019, 08:22 AM   #9
Yup I did all that. Good advice.
Old 04-23-2019, 08:23 AM   #10
basically yeah. you measure carefully and its pretty easy.
Its really easy to overthink it and make it harder than need be.
