Old 09-18-2015, 08:11 AM   #91
Realistically bolts, welds, rivets, self tapping sheet metal screws, hell JB weld would probably work if you used enough of it over a large enough surface area, although that would probably cost more than welder.
Because in the end you are going to skin over it and attach that skin to both the old and new metal I really don't think it will mater that much. This will capture it all together and make it really rigid, like when you tack on the card board back to that super cheap big box store bookshelf.
No mater what you do it will be stronger than a standard RV.
CaptainInsaneo is offline   Reply With Quote
Old 09-19-2015, 06:00 PM   #92
I don't see too many cheap big box store bookshelves doing 60mph down the highway though. I would guess it'll be worse to 'guess and glue' then cover it all up and not even be able to see it wearing and failing from the road stress until it all fails catastrophically.
jake_blue is offline   Reply With Quote
Old 09-19-2015, 09:38 PM   #93
I don't see too many big box stores selling riveted steel shelves either.
My point was that once you attach the skin to the frame it will get really solid real quick, and not to stress the minutia. All of theses answers are a good, better, best while taking in account your personal skills. There really isn't a wrong answer, and there are several right answers. Have you seen how RVs are constructed, seriously there isn't anything you could do that would be worse than one of those. If a bus roof raise was done by an RV tech they would just use 2x2's screwed into the channels with a little dicor for good measure. They still handle highway speeds.
For the record I realllllly don't recommend using JB weld but modern epoxies are really quite good and are used in the construction of super cars all the time, so yeah they could handle 60mph.
Old 09-19-2015, 10:07 PM   #94
Engine: 190hp 5.9 Cummins
When I drove tow truck, we would need three deck trucks to haul most RV collisions off the road. One for the frame, and two for the debris.
Upon impact they explode. Crap everywhere. We got paid good to clean that stuff up.
That is when I decided I was going the skoolie rout.
I cant believe they even alow them stick and staples piles of $hit on the road.
They also burn like a match stick.
Skoolies don't.
Old 09-21-2015, 10:18 AM   #95
Skunky Bus's Avatar
Chassis: Dodge S-600
Engine: 360 V8
Skoolies don't.
I hope this thread doesn't turn into a slugfest. It's got great information and I can't declare either Nat's or EastCoastCB's positions "wrong." That's because my knowledge of welding is very rudimentary. For me, Nat_ster's position here is worth considering as an alternative to learning how to weld properly. As for hat-section stock, that makes sense to me.
A city bus driver in Delaware inadvertently demonstrated the superiority of bus construction over RVs by hitting one that was parked:
[IMG]http://media.nbcphiladelphia.com/images/1200*675/DART+Bus+RV+Crash+Delaware+City.jpg[/IMG]
Any action for which there is no logical explanation will be deemed "company policy."
- Akvol's Second Law of the Corporation
Skunky Bus is offline   Reply With Quote
Old 09-21-2015, 10:41 AM   #96
crazycal's Avatar
10 characters.
Old 09-21-2015, 10:45 AM   #97
I am glad he preformed that experiment for us.
Old 09-21-2015, 12:31 PM   #98
Chassis: TC2000 RE
Engine: 8.3l Cummins
It looks like the only reason the city bus has a hole in it is because the upper face is fiberglass instead of steel.
aaronsb is offline   Reply With Quote
Old 09-21-2015, 05:46 PM   #99
Skunky Bus's Avatar
Engine: 360 V8
Originally Posted by crazycal View Post
10 characters.
Thanks for posting the picture. It was just defying me.
Old 09-21-2015, 06:57 PM   #100
That bus has a trophy!
I don't know how municipal buses compare to school buses in terms of their robust construction... again it probably varies by manufacturer and model.
