Old 09-11-2015, 12:12 PM   #51
Engine: 190hp 5.9 Cummins
I feel cutting the roof compromises structure.
Think about the arch. Then you will understand.
When I cut my hat channels, I had sections of floor drop. They were being held up by the roof.
The roof being one piece is the strongest part of the bus.
The roof needs to stay one piece.
Old 09-11-2015, 12:15 PM   #52
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Sort of like this, but all the way back.
I'd love to have something like this in the transition, but I'm on a budget.
Old 09-11-2015, 12:25 PM   #53
EastCoastCB get outta my head! Haha
jake_blue is offline   Reply With Quote
Old 09-11-2015, 01:53 PM   #54
Stu & Filo. T's Avatar
Coachwork: Crown / Pusher
Originally Posted by jake_blue View Post
I'll look through the build thread to see if anyone's posted pics of this but what are y'alls thoughts on only a partial roof raise? In my mind it seems like the biggest aggravation with such a concept is the fabrication of angled and contoured panels to re-enclose the interior.
I made mine out of fiberglass but if I were to do it again I'd have a sheetmetal shop build it for me.
Old 09-11-2015, 04:42 PM   #55
I love your bus conversion, but cringe evertime I see the way you compromised the roof structure right over the front wheels. That is the most weakest part of the wall structure.
When you cut the roof, the sheeting and rub rails on the walls are forced to take the load that the roof once did.
That would not work out vary well in a roll over.
This is one of the times people are putting looks before strength.
Old 09-11-2015, 04:49 PM   #56
Coachwork: IC
Chassis: CE300
Rated Cap: 32
Hey I feel as strongly about not bolting together a bus as you feel about doing it your way with bolts.
But yeah, things do look unappealing all blocky and square.
Old 09-13-2015, 11:47 AM   #57
I understand your concerns if I was trying to maintain the standards & Regs of a School Bus, I know I didn't take detailed pics & descriptions of all the work i did but I did have a friend of mine who is a Engineer who was involved with the design & building of Nuclear submarines & has been a Engineer for GE for years look at the work I did & he's happy with the mods I did as far as safety for driver & passenger goes, It's still more stout than a S&S .
I do respect a lot of what you offer Nat but if we're trying to maintain School Bus standards then we all should stop what we're doing.
Old 09-13-2015, 12:27 PM   #58
And of course the vehicle still sits on a steel frame which is what carries all the weight anyways. The structural integrity of the shell to carry the load should only ever come into play IF we roll the vehicle over and I don't think that's any of our intentions. The last school bus I saw rolled was still intact albeit slightly angled and all the students (special needs to boot) were unharmed and milling around in the median by the time the first responders arrived. I certainly would never expect to find myself in a rollover situation but I don't think I would feel ill at ease at the survival prospects just because the mods in question happen to be over the wheels. Now in an RV and even a lot of motorcoaches, different story.
Old 09-13-2015, 12:45 PM   #59
And after all, they are still better than a sticks and staples motor home.
Only time I see any body movement is when the bus drives into a flex situation, like a approach. You might get some movement at the fill in point that could cause a leak.
Jacking up my buses I have leaned a ton. Any more than a few inches per corner, and you would be surprised the amount of stress put on the body due to the frame flexing like it was made too.
Old 09-13-2015, 12:48 PM   #60
Amen to that!
