Old 09-25-2019, 12:11 AM   #41
G30’s aren’t unibody they use full frames.
Iqinsanity is offline   Reply With Quote
Old 05-04-2020, 11:42 AM   #42
Joe45's Avatar
I've pretty much given up on the roof-raise/loft idea.
Two reasons:
1. The added work and time, and I want to finish as soon as I can while devoting as much time and effort to make the bus as nice as possible.
2. Most importantly: I am concerned with the height of the bus and being able to go as man places as possible. With a loft the bus would be at about the limit of 13' and that will likely restrict going to certain places due to height clearance.
The one way I can still imagine it is by mounting basically and Aliner top on the roof, and even that would probably become a PIA having to open it up and close it down every night and morning, plus the added chance of leaks, etc.
Joe45 is offline   Reply With Quote
Old 04-10-2021, 10:12 PM   #43
HELLO...I'd love to see your CLERESTORY ROOF ADDITION. Can you post a pic of that bus? Any leak issues?
MDHtravels is offline   Reply With Quote
Old 04-10-2021, 10:24 PM   #44
Joe45's Avatar
Hello! Are you asking me? If so, I decided not to do that because I have a tall roof already and don't have the time.
Old 04-11-2021, 10:07 AM   #45
Simplicity's Avatar
Coachwork: IC / Amtran
Chassis: 3000 / 33' Flat Nose
To verify, the bus ceiling, from floor to ceiling is 6' 6".
And how tall are you?
Besides just wanting a raised roof of some kind, I'm trying to understand why the existing roof isn't tall enough.
I get if you're like six four that you'd like some more headspace, but if you're like even six two, it seems like a lot of work and potential issues to consider any kind of a roof / ceiling raise.
So many other things I can think of to spend your time and money on in a conversion if there's already adequate headroom.
Steve
Old 04-12-2021, 12:30 PM   #46
Joe45's Avatar
The roof on my bus is at about 6'6". I'm 6'. Adding about 1.5" insulation to the floor reduces it a little but not enough for me to warrant a roof raise. Some people do a raise and then also raise the floor, leaving room fro storage and getting over the wheel wells.
