09-02-2018, 08:46 PM
Engine: 9.L
Rated Cap: 64
Rubber flooring
Im at the stage of tearing out the floor. Any advice on removing it..remove the rubber then the plywood but how is the question.
09-02-2018, 10:37 PM
I like the "floor jack" method. Get an edge of the plywood up enough to get a floor jack under it (a 2x4 or two might asset you} and go to town. (no old joke reference intended) This can make the job quicker, and easier.
09-03-2018, 09:06 AM
Engine: 9.L
Rated Cap: 64
Tear off the plywood and rubber at the same time then?
09-03-2018, 10:13 AM
Depends on the condition of it all. In my new bus, it was so bad that the rubber wasn't really stuck to the wood any more, so pulling that up was really simple. Then the plywood was just crumbling apart and I was pulling it up by the handful.
09-03-2018, 10:53 AM
Engine: 9.L
Rated Cap: 64
Ive pulled some of the rubber up around fender well. It was stuck pretty good..ive got all that trim to rip out then see if I can pull it up..i wasnt sure if pulling it up together would make a pain in the A$$ job worser..hope for the best but expect the worst!
09-04-2018, 06:51 PM
Like Brokedown said, IF the plywood is I good enough condition, take em both out at the same time. You'll have plenty of time to make up the time you save, on several other project. Since the rubber has developed "an attitude" I say get that stuff out asap.
09-04-2018, 07:12 PM
Engine: 9.L
Rated Cap: 64
Pulled up a big patch of rubber, the wood is shot. We've had a week solid of heavy rains and the wood is showing me where the water is..its just crumbles in spots. Hoping for the best and expecting the worst when I tear into it..
09-04-2018, 07:34 PM
Once the air hits it, that wet metal floor is going to start rusting in a hurry.
09-04-2018, 08:53 PM
Yeah its always a good idea to mop the floor with ospho or something similar once the metal is exposed. Even if its pristine the phosphoric acid will etch the galvanizing and make the paint stick to it really well.
09-05-2018, 08:36 AM
This...
is why anyone considering a build out should rip up their floor before doing much else. Good start bud. And definitely use a rust treatment before painting. And those rust patterns also give you an idea as to which windows leaked the worse.
09-06-2018, 10:41 AM
Engine: 9.L
Rated Cap: 64
Originally Posted by Tango
This...
I i have a good idea of where its coming in..it follows my roof seams and those windows leak. There is a vent on the roof thats louvers were smashed shut...i fixed them..it leaks..and finally, fugly has a rub rail wind blocker at the top of windows right below gutter..is that common?
09-06-2018, 10:51 AM
I set a Skil saw at 3/4" and cut up along the rows of screws and removed the big pieces of plywood, then it was easier to pry the remaining screwed down parts with stripped heads.
09-06-2018, 07:41 PM
Engine: 9.L
Rated Cap: 64
Thats an excellent idea.
09-18-2018, 12:13 PM
Engine: 9.L
Rated Cap: 64
As i tore into it i realized i way over thought such a fairly simple but physical job.
