Old 07-09-2009, 09:58 AM   #1
Year: 88
Engine: 5.9 cummings diesel
Rated Cap: 70
Runnin water
When I took out the floor heaters I decided to salvage the fans for my glass shop and the pump for water I plan on cleanin the s out of it and wiring it back up to the control panel. Would this mean that I could only run the water when the bus is on or could I have limited use on reserve power? I am grabbing a sink/counter from a habitat restore. Also I am curious how to go about cutting holes in the floor to access a 35 gal tank for clean water and drain to a 35 gal gray water. I have limited expertise but an ability for great understanding. I found little help in the tutorials. A detailed explanation would be awesome.
Movin Right Along
speakeasyglass is offline   Reply With Quote
Old 07-09-2009, 10:03 AM   #2
Steve's Avatar
Re: Runnin water
You just need a hole saw like this one to run the lines through.
Old 07-09-2009, 12:15 PM   #3
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Re: Runnin water
Originally Posted by Steve
...You just need a hole saw like this one to run the lines through...
Make sure it is marked 'bi-metal' (not just for wood), and make sure you know what your obstacles and clearances are behind whatever panel you're drilling through. (Don't ask me how I know... )
Griff is offline   Reply With Quote
Old 07-09-2009, 01:07 PM   #4
Year: 88
Rated Cap: 70
Re: Runnin water
Originally Posted by Smitty
Also, keep in mind that if you mount your water tank above the sink, you won't need a pump for water, gravity will deliver you water with no need for power or pump.
Smitty
Would you suggest making a compartment above the sink inside or mounting one on top either way what methods for refill?
Movin Right Along
Old 07-09-2009, 01:46 PM   #5
Steve's Avatar
Re: Runnin water
For filling my tank I put a garden hose valve on the end of one of the hoses on the tank. I connect my garden hose with the quick connect I put on the end, then open up the valve to fill the tank, close it when it is getting full.
Old 07-10-2009, 11:08 AM   #6
Papabear's Avatar
Coachwork: ward
Chassis: IH
Re: Runnin water
Damn, I need to get busy on my bus, All this work getting done on everyone else's. The only running water in mine, is through my kindey's
"I've never been lost, but I been mighty confused for several days"
Papabear is offline   Reply With Quote
Old 07-13-2009, 10:00 PM   #7
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Re: Runnin water
What would the approx dimensions be for a 35 gallon tank?
ezbme is offline   Reply With Quote
Old 07-14-2009, 08:50 AM   #8
ezbme's Avatar
Re: Runnin water
16W x 48L x 12D (Aprox. 40 Gallons)
Got this from RV Surplus site, but would imagine you could get serveral configurations.
http://www.rvsurplussalvage.com/catalog ... ct_id=2039
Smitty
Thanks smitty for the good site!
Old 07-14-2009, 10:05 AM   #9
Re: Runnin water
1 gal = 231 cu in.
Old 08-16-2011, 10:52 AM   #10
Stuff's Avatar
Re: Runnin water
or insulate and have a heat tape down there and down the lines.
Old 09-16-2011, 12:46 PM   #11
wtd
wtd's Avatar
Year: 1982
Coachwork: Thomas TransitLiner
Re: Runnin water
but add a 35 gallon attached inside to provide gravity feed pressure
Gravity pressure is only about 1/2 psi per foot of elevation, not much elevation in a bus. Picture a water cooler.
Tom
The Rolling Motel Room
Where DIY meets WTF
wtd is offline   Reply With Quote
Old 09-23-2011, 12:24 AM   #12
wtd
wtd's Avatar
Year: 1982
Re: Runnin water
Yeah it's one of those perennially interesting problems that uses up a lotta bar napkins, but when you sober up you just go out and buy a pump ...
Pump takes about 4 amps (mine does anyways), do a few calcs and see just how little power it uses for how much annoyamce it does away with. Total up actually how long the pump actually runs each day, what, maybe 20 or 30 minutes if you put it all together and you get less than 2 amp hours a day ...
Tom
Where DIY meets WTF
help on black water and grey water hookups heath692 Plumbing, Water and Waste 8 04-18-2015 05:57 PM
water tank and quality of water bansil Plumbing, Water and Waste 12 03-01-2012 09:40 AM
Saving Water/Water Reduction Redbear Conversion General Discussions 9 10-06-2009 02:37 AM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 06:26 PM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
