Old 07-09-2009, 09:58 AM   #1
Year: 88
Engine: 5.9 cummings diesel
Rated Cap: 70
Runnin water
When I took out the floor heaters I decided to salvage the fans for my glass shop and the pump for water I plan on cleanin the s out of it and wiring it back up to the control panel. Would this mean that I could only run the water when the bus is on or could I have limited use on reserve power? I am grabbing a sink/counter from a habitat restore. Also I am curious how to go about cutting holes in the floor to access a 35 gal tank for clean water and drain to a 35 gal gray water. I have limited expertise but an ability for great understanding. I found little help in the tutorials. A detailed explanation would be awesome.
Movin Right Along
speakeasyglass is offline   Reply With Quote
Old 07-09-2009, 10:03 AM   #2
Steve's Avatar
Re: Runnin water
You just need a hole saw like this one to run the lines through.
Old 07-09-2009, 12:15 PM   #3
Griff's Avatar
Year: 1982
Chassis: IH S1723
Engine: IH V345 Gas V8
Re: Runnin water
Originally Posted by Steve
...You just need a hole saw like this one to run the lines through...
Make sure it is marked 'bi-metal' (not just for wood), and make sure you know what your obstacles and clearances are behind whatever panel you're drilling through. (Don't ask me how I know... )
Griff is offline   Reply With Quote
Old 07-09-2009, 01:07 PM   #4
Year: 88
Rated Cap: 70
Re: Runnin water
Originally Posted by Smitty
Also, keep in mind that if you mount your water tank above the sink, you won't need a pump for water, gravity will deliver you water with no need for power or pump.
Smitty
Would you suggest making a compartment above the sink inside or mounting one on top either way what methods for refill?
Movin Right Along
Old 07-09-2009, 01:46 PM   #5
Steve's Avatar
Re: Runnin water
For filling my tank I put a garden hose valve on the end of one of the hoses on the tank. I connect my garden hose with the quick connect I put on the end, then open up the valve to fill the tank, close it when it is getting full.
Old 07-10-2009, 11:08 AM   #6
Papabear's Avatar
Coachwork: ward
Chassis: IH
Re: Runnin water
Damn, I need to get busy on my bus, All this work getting done on everyone else's. The only running water in mine, is through my kindey's
"I've never been lost, but I been mighty confused for several days"
Papabear is offline   Reply With Quote
Old 07-13-2009, 10:00 PM   #7
ezbme's Avatar
Coachwork: Thomas Transit Liner
Engine: CAT 3208 Turbo
Re: Runnin water
What would the approx dimensions be for a 35 gallon tank?
ezbme is offline   Reply With Quote
Old 07-14-2009, 08:50 AM   #8
ezbme's Avatar
Re: Runnin water
16W x 48L x 12D (Aprox. 40 Gallons)
Got this from RV Surplus site, but would imagine you could get serveral configurations.
http://www.rvsurplussalvage.com/catalog ... ct_id=2039
Smitty
Thanks smitty for the good site!
Old 07-14-2009, 10:05 AM   #9
Re: Runnin water
1 gal = 231 cu in.
Old 08-16-2011, 10:52 AM   #10
Stuff's Avatar
Coachwork: Goshen
Engine: 7.3
Rated Cap: 25
Re: Runnin water
or insulate and have a heat tape down there and down the lines.
help on black water and grey water hookups heath692 Plumbing, Water and Waste 8 04-18-2015 05:57 PM
water tank and quality of water bansil Plumbing, Water and Waste 12 03-01-2012 09:40 AM
Saving Water/Water Reduction Redbear Conversion General Discussions 9 10-06-2009 02:37 AM
12V Water pump for fresh water? ezbme Plumbing, Water and Waste 1 05-29-2009 06:26 PM
Black water/ Gray water tank travlenhippie Plumbing, Water and Waste 3 10-21-2008 08:53 PM
