04-01-2019, 06:44 PM
Year: 2006
Engine: 906 Mercedes 6.4l turbo diesel
Rated Cap: 24 passenger
Securing the doors and hatches
I’ll be starting on my 2006 Thomas Freightliner conversion and was hoping for enlightenment on the best tools and tactics for securing the doors and hatches. I am doing a very light touch conversion, and want to keep the doors and hatches original as possible. But there is not a single lock to be found.
I assume there is a good place to buy locking latches for the battery and storage hatches, the wheelchair lift and emergency exit door? Links?
I believe I could secure the main bi-fold door with a swing bar and padlock? Is there a more straightforward solution?
It makes perfect sense that it isn’t lockable. They used to live in a motor pool surrounded by chain link and concertina wire, and had nothing on board worth stealing other than the bus itself. If the doors and hatches could lock, it would probably be a nightmare for motor pool staff when drivers lost the keys.
However, I need to be able to lock up. Any guidance welcome.
04-01-2019, 07:21 PM
Chassis: G30~Chevy cutaway
Engine: 5.7/350 Chevy Vortec
Try these folks. They've got a good selection and variety of paddle handle lockable latches:
https://www.mcmaster.com/flush-mount-latches
04-01-2019, 08:01 PM
I found this deadbolt the cheapest and easiest way to secure a back door. Lock was $9. Put a spacer on the back of the door, drill the hole for the cylinder, 4 screws to mount it to the door. Weld the catch on the red arm and you're done.
04-17-2019, 11:24 PM
Year: 2008
Chassis: PB105
Engine: VT365 6.0L v8 Diesel
I saw someone used this same deadbolt on the front split door and it worked fine. It's what I'm planning to use when the time comes.
04-25-2019, 03:20 AM
Year: 2006
This is fantastic! I apologize for the delay in responding...I have been wandering the earth in a land of shitty WiFI.
As I understand it, the whole would be to provide the external lock cyliner? So a fairly good sized hole? I am so new to this, but do you use drill oil when drilling into the sheet metal? Any bit preferences?
04-25-2019, 08:01 AM
Year: 1975
Coachwork: Chevy
Chassis: 8 window
Engine: 454 LS7
Rated Cap: 24,500
you would use a hole saw of the correct size to fit the lock cylinder - hole saws are a bit pricey, but the alternative is drilling a bunch of small holes, then a lot of filing to make the cylinder fit properly
04-25-2019, 10:14 AM
The hole is made with an appropriate sized hole saw.
04-26-2019, 08:06 AM
Coachwork: Me
Chassis: 2001 IC
The almighty Hole Dozer. These things will rip your arms off when you get into the larger ones if your not careful. I used a six inch recently and it almost got away from me. Glad I ate my Wheaties that day.
05-10-2019, 12:41 PM
Year: 2006
I have owned a set of hole saws for aeons, but have never used them on metal. Clearly it can be done, but do you just let it rip or use a little drill oil? Carpentry is old hat to me, metal is a whole new world.
05-10-2019, 01:01 PM
Rated Cap: 34
Oil will help, but slow, steady, and level wins the race. The bits 'grab' because the cutting edge has tilted in the work, and is cutting deeper on one side than the other. Over the years, I've broken the handles off 3 different 1/2" drills by going faster than I should have.
05-10-2019, 01:11 PM
I found a "cutting and drilling lube" at NAPA that is water based and doesn't leave the mess that machine oil does. Works well and is handy in a regular spray bottle.
PLFking, What is your secret? I would rather break handles than have the drill try and rip my right arm off Where you break a handle I wind up with a sprained wrist instead.....
05-10-2019, 01:37 PM
Engine: DT466E (195hp, 520tq)
We put a simple deadbolt on the back door like this:
For the wheelchair door we used a lock like this:
https://www.google.com/url?sa=i&sour...57599560638180
We also used the deadbolt like o1marc posted on the front door, but don't have any closeup pictures of it.
Dave
05-10-2019, 01:42 PM
Chassis: Saf T Liner MVP 11 window 32’
Engine: CAT 3126E
I'm planning on drilling a hole on the lever & keep on the inside of each emergency exit. A carabiner will go in each of those.
For the front door I'll use this on the outside:
https://www.masterlock.com/personal-...oduct/M736XKAD
On the inside (when we're living in the bus), I'll just use an old fashion bar that sits in a cradle.
05-10-2019, 01:46 PM
The problem we saw with the padlock solution is that someone could lock it from the outside while we are inside. The deadbolts can be locked and unlocked from the inside (levers) or outside (keys) so we will never be locked in. The hasp lock we have on the wheelchair door is only on the outside since we can't exit through that door anyway, since the ramp is still in place.
Dave
05-10-2019, 02:00 PM
Rated Cap: 34
You're the one with the valuable secret. I'd rather sprain my wrist than have to buy another drill.
05-10-2019, 02:34 PM
Engine: CAT 3126E
I thought of the lock while inside scenario, but figured the chances of that are slim & if it happens I’ll walk out the e door and cut it.
05-10-2019, 06:00 PM
Chassis: IH 3800, 8 window
I went this route. While prepping and loading to leave NH, I installed a latch post safety hasp on the swing-out front doors. Not pretty, but it kept undesirables out.
Well, except for me.
I had the key...
Point being, when not otherwise locked shut, I lock the hasp in the open position.
Doubly beneficial: no prankster can lock me in, and I am SO much less likely to misplace the lock!
07-23-2019, 05:08 PM
Coachwork: IC/AMTRANS RE
Engine: T444E 7.3 w/ MD3060
Using pad locks is a bad idea, they only help keep honest people honest. They are far to easy to defeat.
Not to mention it looks horrible.
I too am looking for a good solution to locking the main door.
07-23-2019, 05:14 PM
I am looking for that less-ghetto-looking solution, as well.
But in the meanwhile, I guess it's done well enough to keep all of the local honest tweaks on their side of the bulkheads...
07-24-2019, 06:51 AM
Coachwork: Me
Chassis: 2001 IC
The pad lock is just used to keep the intruder busy for a few minutes while the wife and I fight over who gets to shoot the thief.
