Old 05-04-2017, 01:11 PM   #21
Brewerbob's Avatar
Originally Posted by Sasquatters View Post
It was never a joke. We did it with the full intentions of it working. It was great. Similar tools sell for $600.
Electric Foam Saw | Sasquatters
You sasquatches are short!! I can barely stand straight in the center.
So, if you were to do it again would you still use a 36" blade? Looks like a 24" would be about perfect. I need to measure from the floor to the bottom window and the depth of the walls.
Old 05-04-2017, 01:13 PM   #22
Sasquatters's Avatar
Coachwork: Thomas EF
Well had we known there were different interior heights we would have found a taller one. Everyone says, "next bus" right? 🤷🏻*♂️ Yes we would have still used a 36" blade. 24" is the measurement from rib to rib. This means the end of your saw would be smashing into one of the metal ribs. Did that a few time by mistake with the 36" one. Doesn't feel good. Also, 36" was perfect for doing the wall panels.
Our Blog | Facebook | Instagram
Sasquatters is offline   Reply With Quote
Old 05-04-2017, 01:23 PM   #23
Brewerbob's Avatar
I dunno if that was you or your helper in teh video but you don't NEED a roof raise. Even with a 78" bus I would have WANTED to do a raise just for cabinets tho I would have been tempted to leave 78" alone.
24" are they? Damn haven't measured that either. Wait, that can't be right. I have both 25" and 32" windows for horizontal widths. This is going to be fun when it comes time to add new skins on the outside. Maybe for ease of interior, I'll use 2x4s against the outside skin and put them on 16" centers. 24" centers if I get lazy/cheap.
Old 05-04-2017, 01:27 PM   #24
Serreated knife for Foam (Bread knife) 12"
We wanted to do a roof raise but we just don't have time. We don't want this to turn into a 3 year project. Also, raised roof buses don't withstand rollovers as well as stock buses. Strange that you have different sized windows. The one working the saw (me, Dustin) is from Sasquatters. Our friend filming is from @RussBussTravels They are building a bus literally right next to ours.
Old 05-04-2017, 01:42 PM   #25
REDD's Avatar
Coachwork: Thomsass
Chassis: FreightShaker
Engine: 5.9 Cummins 5 speed
Rated Cap: 2 ATV's and friends
Originally Posted by Versatile View Post
I was talking about rigid foam
When I did my basement I ran the rigid board through my table saw, jig saw for the plug boxes, hole saw for pipes etc.
Old 05-04-2017, 01:43 PM   #26
We helped cut our friends mentioned above using a circular saw. It was dangerous and melted.
Old 05-04-2017, 01:51 PM   #27
Brewerbob's Avatar
It's just another 2 weekends for a roof raise. I'm planning on a 2 yr build but don't have any hard deadlines.
Old 05-04-2017, 01:52 PM   #28
Perhaps if you have a welder. We tried to get a welder to come out and install our flat floors after we cut out the wheel wells. Seems no one needs work these days. That project took over a month and was still not done exactly how we wanted/needed.
Old 05-04-2017, 02:09 PM   #29
Brewerbob's Avatar
I do. Now if I onlyknew what the hell I was doing with it...
Bought a MIG and borrowed fire (oxy/ace) from a friend. I haven't played with the fire one yet. I need to call some metal fab shops and see who has some 18 gauge sheet scraps I can have so I can practice.
Old 05-04-2017, 02:10 PM   #30
Yikes. You're doing it by yourself without ever welding? Good luck brother! If it turns out nice do ours.
Old 05-04-2017, 02:15 PM   #31
Brewerbob's Avatar
Oh come on. I'm not a total noob. I have a good solid hour worth of welding time with other projects so far.
I haven't welded anything as thin as 18 gauge. My worry is burnging thru it. I've got teh same welder that EastcoastCB has. His buddy Eddie is a professional welder and said it did just fine on CCCB's roof raise. So, I know the welder is capable. Figuring out if I'm capable will be the next part.
Old 05-04-2017, 02:46 PM   #32
Brewerbob's Avatar
Sweet!! Just got off the phone with a local fab shop. talked to a guy that will give me some scrap 18 gauge to play with.
