Old 06-16-2004, 12:31 PM   #1
Steve's Avatar
Sewer Systems
You will have both a gray water tank (shower and sink) and a black water tank (from toilet). You'll need much more capacity for your gray water tank than black water tank. At a campground you can leave the gray water valve open once you're hooked up to the campground's sewer system. When you shower, it goes right through your system, through your hose, and into their sewer system. But do NOT every leave the black water tank "open". It needs to be filled up at least 1/2 to 2/3 to create enough water pressure to flush out completely. A good tip: keep your gray water tank closed for a day or more before flushing the black tank. Then after dumping the black tank, drain the gray tank to flush out the hose. Also, after dumping the black tank for the last time before storage, fill it at least half full of water, add dishwasher soap, drive down the road to shake it all up. Then stop at the last dump station before getting home and empty the black tank again. These systems are really not all that complicated; and they're quite easy to use.
All of the tanks have vents. Be careful that the pipes remain clear of debris, birds, etc. Usual symptom of blockage is odor in the rig. When this occurs, check the vents.
Fresh water tank sits above the flooring, while waste tanks hang below, are more exposed, and can develop leaks -- particularly if you're traveling with full tanks. Better to empty tanks before traveling. There are kits which can be used to patch a tank which has developed a leak, providing it is not so large as to be unrepairable.
Also, don't trust the gauges that pretend to tell you how full the gray and black water tanks are. They typically don't work accurately. You'll get false readings. Pretty soon you'll get a "feel" for how often you'll need to dump the tanks. Pretty soon all this gets to be easy too!
Accessories
Sewer hoses come in three weights, light, medium and heavy duty. These might be classified as: tear easily, tear harder, and tear eventually. The heaviest duty hoses do not compress well, and will require a larger storage compartment.
Couplings and connectors: Their recommendation from the various brands and styles is the blue Presto-Fit kits.
Hose carriers: Many are carried in bumper, which tends to rust and scrape the hose when storing and removing it.. PVC carriers which are vented can tend to minimize this problem, and can offer more space for extra lengths of hose when a longer hose length is required..
Tote tanks ("blue tank") are used to fully or partially drain your gray or black water, and drive the waste water to the dump station in another vehicle. This lets you leave your RV parked when boondocking.
"A Sewer Solution" -- like mascerator pump lets you pump uphill. However, it does require the use of water. Mascerators requires no water, but do require electicity.
Rest area dump stations, and the ettiquette thereof: Most RVers will find rest areas convenient places to dump. The "Rest Area Guide" provides a resource for locating a dump stations. Many states are closing the dump stations due to vandalism and poor manners by RVers. One of the key problems: Always use a hose. This seems overly simple, but unfortunately too many RVers violate this rule. And of course clean up after you're done so the next RVer starts with a clean area.
Chemicals: Very few RV chemicals still contain formaldahyde. But some parks still require emptying holding tanks before entering the park. Newer products are enzyme type -- tablets, liquid, powder, etc. Hot weather will require a bit more chemical to work effectively. A teaspoon full of baking soda every couple of months can help fight odor in black water tanks.
Sewer hoses come in 10 or 20 foot length hoses. If you have a 20' hose only, you'll be parked right next to the sewer. If you have a 10' hose, you'll be miles away. Tip: Take a 20' foot hose, cut it so you have a 6' hose and a 14' hose. Also carry a 10' hose. That gives you anything from 6' to 30'
Water hose: Use this to fill your water tank.
Myths
"Home brew" remedies are used by some in lieu of purchased chemicals. Lysol, PineSol, baking soda and even "a few aspirins" are advocated by some RVers. But some of these can damage toilet seals and valves. A safer solution are chemicals that are specifically designed for use in RVs.
You must use specialized toilet tissues. Maybe in old recirculating toilets. But now just buy the cheapest brand of regular tissue, and it will work as well.
Black waters smells worse than gray water. Not necessarily, because we seldom put chemicals in gray water. The soaps and detergents tend to kill off bacteria in the gray water tanks.
Coyote dumping is okay (down a rabbit hole, etc). No, that's not okay, and it's illegal. The effluents and chemicals will permeate the ground and invade water supply resources.
Tips
Keep your black water valves closed when you're parked. And leave it until at least 3/4 full. If you need to dump before it's full, full it w/a hose to 3/4 full before dumping. Only by having a substantially full tank can you ensure that it will properly empty all solid wastes.
Never drag a sewer hose across dirt or concrete when setting up or preparing to leave -- it will quickly result tearing. And be vary wary of weed whackers used by RV park maintenance personnel..
Be aware of local state laws. A doughnut, for example, will be required in some jurisdictions -- so be equipped with fittings which will keep you legal in all states. Oregon is just one example of a state which has special requirements.
Always dump gray water after you've dumped the black water, as it will tend to clean out the sewer hose.
Use drinking water safe hoses only for fresh water. Otherwise you'll get a plastic or rubber taste.
Periodically (every few months) clean fresh water lines, tank, and hot water tank by flushing and then following w/weak bleach solution. Also flush weak bleach solution through your fresh water hose. More specifically: Disonnect from city water, and then drain the fresh water tank. Next add back about 15 gallons of weak bleach solution. Turn on each cold water line until bleach smell appears. Wait 4 hours. Then empty the hot water tank. With city water still disconnected, turn on the hot water, which will fill the hot water tank w/weak bleach solution. Run solution to each hot water faucet in the rig until bleach smell appears. Wait four hours. Next empty fresh water and hot water tanks, refill with fresh water, and run fresh water through all hot and cold water lines. Empty fresh water tank once more, and refull with fresh water.
Sewage
Never dump on the ground anywhere. It's illegal in almost every state. And it's certainly terrible manners as well. Many service stations out West have a disposal station for a fee. Flying J is particularly RV friendly. They'll have dump station and propane. Newer flying J's have fuel plazas just for RVs -- but regrettably they're poorly designed and often too tight for big rigs -- so bigger rigs will want to fuel up with the trucks. Some chains are not RV friendly. Petro is one. Unfortunately some states are closing their dump stations. It's because RVers use bad manners. Always use a hose; and always hook up the hose to the dump station first, and then to your RV.
Bus Electrical Systems - AC Les Lampman Conversion Tutorials and How-to's 180 12-13-2016 05:50 AM
Bus Electrical Systems - DC Les Lampman Conversion Tutorials and How-to's 65 12-13-2016 05:49 AM
rv sewer hookup bansil Conversion General Discussions 6 09-21-2014 11:05 AM
Power hook-ups, sewer dump, which side? Abbott Conversion General Discussions 7 06-18-2008 09:40 PM
Skoolie in Skelewags Sewer Art Steve Everything Else | General Skoolie Discussions 2 02-12-2008 02:58 AM
