Old 03-02-2018, 07:53 PM   #21
Jdawgsfanasty's Avatar
Originally Posted by Megabea View Post
this is the view behind my wall skins , really glad that i decided to look.
Yep...what a mess huh?
Jdawgsfanasty is offline   Reply With Quote
Old 03-04-2018, 12:49 PM   #22
simplyusandabus's Avatar
Chassis: AmTran IS3009
Engine: Cummings DT466
Rated Cap: 27
Instead of burning through a bunch of cut off discs with my angle grinder, here’s what I did. Worked great.
I removed all the screws along the bottom & sides. I scored the top (about 1 inch below the window). Scored it with the angle grinder but I did NOT cut all the way through. Just like when you score drywall and bend and break it. Once I had the galvanized steel scored, I bent it up and down and after a couple of times up and down, the entire piece just snapped off.
Didn’t even burn through a entire disc and it definitely took less time and energy.
simplyusandabus is offline   Reply With Quote
Old 03-04-2018, 12:53 PM   #23
Seems I saw a video demonstration of this procedure
